dirtywaterdiver 2 #1 Posted May 23, 2025 So had a pulley break off it's center hub section. The hub portion is still bolted to the spindle. What am I missing, have not found a hole to shove a screwdriver into, how do I stop the spindle from turning so I can remove the nut and swap in a new pully. My deck is Model # 79108 and the pulley is a 88-5330 Share this post Link to post Share on other sites
953 nut 63,982 #2 Posted May 23, 2025 There is an 1 1/8" hex head area between the blade and the spindle where a thin 1 1/8" wrench can be inserted. This manual should be helpful. 1 Share this post Link to post Share on other sites
Ed Kennell 44,667 #3 Posted May 23, 2025 (edited) I use a block of wood to lock the blade and spindle to the deck shell. Oh,and to the Edited May 23, 2025 by Ed Kennell 4 Share this post Link to post Share on other sites
Horsin'round 368 #4 Posted May 23, 2025 2 hours ago, Ed Kennell said: I use a block of wood to lock the blade and spindle to the deck shell. 1 Share this post Link to post Share on other sites
Horse Newbie 7,402 #5 Posted May 23, 2025 I used a block of wood too, then I graduated to an impact gun. 3 Share this post Link to post Share on other sites
dirtywaterdiver 2 #6 Posted May 24, 2025 I tried a block of wood and my impact. It was an awesome way to quickly uninstall the blade. LOL 2 Share this post Link to post Share on other sites
dirtywaterdiver 2 #7 Posted May 27, 2025 There are NO flat spots on the spindle for a wrench. Nowhere in those manuals does it have instructions for removing a spindle shaft. Share this post Link to post Share on other sites
Ed Kennell 44,667 #8 Posted May 27, 2025 OK, use a chain, strap, or pipe wrench on the pulley OD. No big wrench, weld a bar to the pulley. No welder, drill two holes for pins spanner wrench style. Share this post Link to post Share on other sites
