hotajax 284 #1 Posted May 19, 2025 (edited) Need a part number for Toro / Wheel Horse 48" deck. The deck model number is 78361. Am looking for the part number from McMaster-Carr for the rear wheels on the deck. The ones with the zirc fitting. If you know the exact SKU from McMaster, I'd be very appreciative. Actually, I don't know if M-C even makes this wheel. But if they do, and you bot one, that would be very good. Thanks. Edited May 19, 2025 by hotajax Share this post Link to post Share on other sites
953 nut 68,466 #2 Posted May 19, 2025 (edited) I don't have a McMaster number but Lincoln at A to Z Tractor has some good ones. https://www.a-ztractor.com/advanced_search_result.php?keywords=deck+wheels Edited May 20, 2025 by 953 nut fat finger Share this post Link to post Share on other sites
lynnmor 9,008 #3 Posted May 20, 2025 If you come to the Big Show there is usually a ton of them there. McMaster-Carr doesn't make anything, they are a distributor of parts. Share this post Link to post Share on other sites
Lee1977 7,750 #4 Posted May 21, 2025 The hub in Wheel Horse deck wheels is soft splintered steel, they do not hold up no matter how much you grease them. They are easy to drill out and add bushings if the tire is still good. 1 Share this post Link to post Share on other sites
