nigel 150 #1 Posted May 19, 2025 My engine governor seems to be cutting in all the time causing hunting, anyone know a fix ? Share this post Link to post Share on other sites
pfrederi 21,046 #2 Posted May 19, 2025 Have you tried adjusting high speed mixture too lean can cause surging Governor initial set and sensitivity 2 Share this post Link to post Share on other sites
Wayne0 1,624 #3 Posted May 19, 2025 (edited) I saw the title and automatically went to "12 Ga. hunting" Edited May 19, 2025 by Wayne0 1 Share this post Link to post Share on other sites
wallfish 20,510 #4 Posted May 19, 2025 Most common cause of rpm hunting would be carb/fuel related. If you can use the choke to even out the rpm and stop the hunting, it's fuel restriction from the carb. (The choke used would be matching air to fuel ratio) Clean it thoroughly and it should solve the issue. 2 Share this post Link to post Share on other sites
nigel 150 #5 Posted May 19, 2025 13 minutes ago, wallfish said: Most common cause of rpm hunting would be carb/fuel related. If you can use the choke to even out the rpm and stop the hunting, it's fuel restriction from the carb. (The choke used would be matching air to fuel ratio) Clean it thoroughly and it should solve the issue. Many thanks I will try that 👍 Share this post Link to post Share on other sites
nigel 150 #6 Posted May 19, 2025 Many thanks I will try that Share this post Link to post Share on other sites
nigel 150 #7 Posted May 19, 2025 2 hours ago, pfrederi said: Have you tried adjusting high speed mixture too lean can cause surging Governor initial set and sensitivity Share this post Link to post Share on other sites
peter lena 10,014 #9 Posted May 19, 2025 @nigel have any fuel filters on that ? drop the fuel bowl , if its loaded with debris , its probably fuel hose break down , also fuel tank related , have a seperate gallon jug just for running in any carb issues , heavily treated with cleaners , easy to hook up to fuel pump , and run the engine in that separately , tune / adjust , with verified clean uuel , carb issues grow if not addressed , you are on track , pete 1 Share this post Link to post Share on other sites
