John2189 561 #1 Posted May 17, 2025 It will not turn to tighten belt. I hate to put the channel locks on it for fear of braking it Share this post Link to post Share on other sites
1968Commando 171 #2 Posted May 17, 2025 7 minutes ago, John2189 said: It will not turn to tighten belt. I hate to put the channel locks on it for fear of braking it It could maybe use some penetrating oil, do you have any pb blaster? Share this post Link to post Share on other sites
8ntruck 8,575 #3 Posted May 17, 2025 . Marvel Mystery Oil, Kroil, Rust Buster are other possibilities. Time is your friend here, too. Several applications over several days will likely be needed, as it took some time to rust up. 1 Share this post Link to post Share on other sites
wallfish 19,069 #4 Posted May 17, 2025 Oil oil oil and take it slow. Back and forth, back and forth and rinse and repeat until you can get'er moving freely. 2 Share this post Link to post Share on other sites
953 nut 63,982 #5 Posted May 17, 2025 If you can remove the mule drive and situate it where the knob is the lowest point the penetrating oil will be able to do the most good. 1 1 Share this post Link to post Share on other sites
adsm08 4,155 #6 Posted May 17, 2025 12 minutes ago, 953 nut said: If you can remove the mule drive and situate it where the knob is the lowest point the penetrating oil will be able to do the most good. Right. That's what Oxy-Acetelyne is for. 2 Share this post Link to post Share on other sites
953 nut 63,982 #7 Posted May 17, 2025 6 minutes ago, adsm08 said: Right. That's what Oxy-Acetelyne is for. Wouldn't that be a bit rough on the plastic knob? Share this post Link to post Share on other sites
peter lena 9,716 #8 Posted May 17, 2025 @John2189 very often refer to a lubrication creep , most of the stuff I see is rust bound , especially like the rusty cables that sound like a jack saw 0n a threaded rod , nothing moves , what could you possibly do ? regularly get after things that are SAPOSED TO MOVE , make the rust run out . 3-1 penetrating oil does a very good job , personally like super lube hydraulic oil , small bottle , on things that already move , keeps them that way , rust dust is your , heads up , pete Share this post Link to post Share on other sites
8ntruck 8,575 #9 Posted May 17, 2025 One thing I forgot to mention - trying to tighten a stuck bolt slightly will sometimes help to loosen it. Of course, if you try to tighten it too much the whole head of the bolt will become very loose.... 1 Share this post Link to post Share on other sites
JimSraj 564 #10 Posted May 17, 2025 Just a thought on this. You probably know this already but…. To tighten the belt you will be turning the knob counterclockwise Share this post Link to post Share on other sites
adsm08 4,155 #11 Posted May 17, 2025 (edited) 10 hours ago, 953 nut said: Wouldn't that be a bit rough on the plastic knob? But yes, it would. I may or may not have only skimmed the begining of the thread and missed that we were working with a plastic knob and not stuck adjusting threads. Edited May 17, 2025 by adsm08 1 Share this post Link to post Share on other sites
