kbert1171 1 #1 Posted May 11, 2025 I have a 1969 Raider 12 with the 12 hp Kohler and it needs a new starter. What model is the engine or starter please? 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,920 #2 Posted May 11, 2025 Click on the wiring picture in this link. Then on the first thumbnail that comes up. That is tractor Details when built that contains the engine model number and specification number. 2 Share this post Link to post Share on other sites
ebinmaine 76,544 #3 Posted May 11, 2025 5 hours ago, kbert1171 said: needs a new starter Have you disassembled your existing starter? 1 Share this post Link to post Share on other sites
953 nut 63,559 #4 Posted May 11, 2025 6 hours ago, kbert1171 said: I have a 1969 Raider 12 with the 12 hp Kohler and it needs a new starter. What model is the engine or starter please? The "NEW" starter motors available on the internet (eBay & Amazon) are quite often junk that is not worth buying. I presume you have tested your battery and the starter motor by running a jumper from your fully charged battery directly to the starter post. Here are a couple of places to buy parts; https://www.jackssmallengines.com/Products/KOHLER/starter-part/s and http://www.psep.biz/store/kohler_starter_parts.htm?srsltid=AfmBOoqw1Cc-j9Jzcxckr9A3zlHTaTQVjoMf71pjOUb5F9YUIR7XypMX The thread below should be helpful when you dive into the starter to diagnose the problem. 1 Share this post Link to post Share on other sites
ri702bill 10,972 #5 Posted May 11, 2025 5 hours ago, ebinmaine said: Have you disassembled your existing starter? The only part not repairable / replacable on these starters is the housing/magnet assembly. IF the magnets are broken or severely chipped, it throws off the required symmetry of the magnetic field. This happens either by dropping the starter, or more often, when some maroon hits it with a hammer... Replacing the bushings, brushes & springs is a rather easy task... 1 Share this post Link to post Share on other sites
