lawnmowermad 0 #1 Posted May 7, 2025 Hi i purchased a r26 last and am slowly restoring it ,realised the original engine is no good as it has a worn bore,so I sourced another tecumseh 5hp vertical shaft engine alot more modern than the orignal but I don't no what the maximum rpm it should safely run at so I've purchased a cheap tachometer can any one shed some light on the engine speed at max rpm Thanks Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,918 #2 Posted May 7, 2025 Should be something in one of these and there are more Share this post Link to post Share on other sites
