John2189
Kohler CH 20
John2189
Ok. I put air pressure into the cylinders cold. Both cylinders air is passing out the intake. It does have hydraulic lifters,could that be why?
I did a compression test. One cylinder was 145  and other was 110. Again it was cold.
this motor only has 900 hours on it. It was a mowing tractor for mabey 5 years then for 20 years it only plowed snow, so it sat unused for years.
Oh and it has a lot of blowby in the crankcase, so much that the vacuum fuel pump would not work, so I put a valve cover pump on it.
is it worn out?
Edited by John2189
oliver2-44
Yes, i've read that the hydraulic lifters can leak down and effect a compression test.
I've also read manufacturers literature recommending the engine be at operating temperature for both of these test.
As to is it wore out?  Redo the test hot.
Maybe it just needs a de-carbon and valve job.
JoeM
If you had a collapsed lifter, these would be really bad. I consider good compression on a ch engine to be above 150.
that blow by is telling the story.
900 hours mean nothing if good routine maintenance was not preformed.
the best test is a leak down on a warmed up engine.
by what you are saying not sounding too good.
John2189
I’ll check compression and leak down when warm tomorrow. I got a feeling it won’t change much
Wild Bill 633
Remove the breather cover to check and see if the breather reed valve is broken.
Edited by Wild Bill 633
John2189
its ok.
RED-Z06
Early command Twins could have head gasket problems, your blowby could be related to this, as well as the low number.
Fordiesel69
Kohler command engines are really good but they can blow head gaskets.  Tear the heads off and spend some time doing a valve job and reseal.
John2189
That is what I’m planning on doing.
