Dcarr4510 8 #1 Posted May 6 Hello. Purchased my first wheel horse today (314-8). Having an issue with shifting into High range. It acts like the lever doesn’t have enough throw to get into high range. All gears function in low range. It seems to drop in between low and high when the lever is moved to the high position. Any ideas on what may be worn out/bent/broken to cause this? 1 Share this post Link to post Share on other sites
Ed Kennell 42,186 #2 Posted May 6 The pin that connects the shift lever to the shaft may have sheared. 1 Share this post Link to post Share on other sites
Dcarr4510 8 #3 Posted May 6 28 minutes ago, Ed Kennell said: The pin that connects the shift lever to the shaft may have sheared. I thought so too, but there was a bolt with two jam nuts in place of the roll pin. No noticeable slop from the shaft to the shift lever. Share this post Link to post Share on other sites
oliver2-44 10,781 #4 Posted May 6 (edited) Lots of friendly help here and a little kidding around. sometimes were like little children! This thread has great pictures of the internal hilo shift mechanism parts. The hilo shift fork and fingers are a known weak point and they can bend or break. But before you decide you have to dissemble it, try this: Jack the rear of the tractor up enough so both wheels are off the ground. With the weight off the drivee components try to move the hilo shifter. you might try gently rocking the rear wheels while you try to move the shifter. Have you checked to see if the transmission has water in the oil? If the rubber shifter boot on the gear shifter is in bad condition moisture/water can run down the shaft and get in the transmission. The hilo shift forks are known to get rusted and stick or be hard to move due to rust. if your transmission oil is milky looking it has water in it. Sometimes you can drain the oil, refill with diesel or kerosene. Then with the rear on jack stands run the tractor through all gears multiple times and try to move the hilo multiple times. Let us know what you oil look like and we can go from there. Edited May 6 by oliver2-44 2 Share this post Link to post Share on other sites
Dcarr4510 8 #5 Posted May 6 39 minutes ago, oliver2-44 said: Lots of friendly help here and a little kidding around. sometimes were like little children! This thread has great pictures of the internal hilo shift mechanism parts. The hilo shift fork and fingers are a known weak point and they can bend or break. But before you decide you have to dissemble it, try this: Jack the rear of the tractor up enough so both wheels are off the ground. With the weight off the drivee components try to move the hilo shifter. you might try gently rocking the rear wheels while you try to move the shifter. Have you checked to see if the transmission has water in the oil? If the rubber shifter boot on the gear shifter is in bad condition moisture/water can run down the shaft and get in the transmission. The hilo shift forks are known to get rusted and stick or be hard to move due to rust. if your transmission oil is milky looking it has water in it. Sometimes you can drain the oil, refill with diesel or kerosene. Then with the rear on jack stands run the tractor through all gears multiple times and try to move the hilo multiple times. Let us know what you oil look like and we can go from there. Awesome thank you for the tips! I'll do those checks this afternoon, and report back lol. I'll take a closer look at the 8 speed write up as well. Share this post Link to post Share on other sites
squonk 43,943 #6 Posted May 6 (edited) The Hi/Lo shift fork is made out of flimsy metal with a crappy weld. Most likely it's bent or broken. Edited May 6 by squonk 2 Share this post Link to post Share on other sites
wallfish 18,242 #7 Posted May 6 8 hours ago, Dcarr4510 said: It acts like the lever doesn’t have enough throw to get into high range Sometimes the gear teeth will butt into each other when shifting back and forth and not engage keeping the lever from not moving all the way. I would have to let out the clutch pedal sometimes then push back down to spin the gears so they're in a different position. This won't help if the fork is bent or broken. It sure seems as though the PO had some kind of issue as well if the pin was replaced with a bolt. 4 Share this post Link to post Share on other sites
953 nut 60,355 #8 Posted May 6 Those square cut gears have to be JUST RIGHT to mesh. I turn off the ignition, place the gear selector in first gear, and play around with the HI / LO lever while rocking the tractor forward or backward and when the sweet spot is found it will slide right in. 5 Share this post Link to post Share on other sites
Ed Kennell 42,186 #9 Posted May 6 10 hours ago, Dcarr4510 said: I thought so too, but there was a bolt with two jam nuts in place of the roll pin. No noticeable slop from the shaft to the shift lever. The fork is probably damaged if the PO has allready sheared the lever roll pin while trying to shift the hi/lo. 1 Share this post Link to post Share on other sites
Dcarr4510 8 #10 Posted May 6 Thanks for all the suggestions guys. I'll put the info to use this afternoon. I also found a freshly rebuilt 8 speed on FB Marketplace here in MI if things aren't looking to good. 1 Share this post Link to post Share on other sites
oliver2-44 10,781 #11 Posted May 6 (edited) If happen to go the rebuilt route, get the details of what was done. Here’s my opinion to call it rebuilt. 1 were all bearings replaced or just bad one? Mandatory the axle bearings be replaced. Bonus if axles polished in bearing area 2 were all seals replaced, All mandatory 3 Any pictures, especially of cluster gear and Hilo shift forks 4 Gasket used center split joint, not silicon RTV. PS we can walk you through rebuilding yours if it needs it. But with Steves excellent videos you might even need us. They are actually not hard to rebuild. I find them very enjoyable. (Except for those little shifter rail balls) Edited May 6 by oliver2-44 2 Share this post Link to post Share on other sites
Dcarr4510 8 #12 Posted May 6 6 hours ago, oliver2-44 said: If happen to go the rebuilt route, get the details of what was done. Here’s my opinion to call it rebuilt. 1 were all bearings replaced or just bad one? Mandatory the axle bearings be replaced. Bonus if axles polished in bearing area 2 were all seals replaced, All mandatory 3 Any pictures, especially of cluster gear and Hilo shift forks 4 Gasket used center split joint, not silicon RTV. PS we can walk you through rebuilding yours if it needs it. But with Steves excellent videos you might even need us. They are actually not hard to rebuild. I find them very enjoyable. (Except for those little shifter rail balls) Here's the description for the transmission I was looking at. "Wheel Horse 8 speed transmission 1 1/8 axles 8 pinion differential. Rebuilt a few years ago but never found project for it. Beadblasted inside and out, any worn gears replaced. All needle bearings and seals/ gasket was replaced and painted with automotive paint. Will not find a nicer transmission. $450 located in South Haven". He has pictures of the case open showing the gears and they look good. I'm not sure what something like this would usually go for, but its the only one I can find near me. Share this post Link to post Share on other sites
Dcarr4510 8 #13 Posted May 7 I drained the oil in the transaxle. Did have a little bit of milkyness to it. Shift boot was not damaged, but scooted its way up the shift lever. Guessing thats how moisture got in. My guess is what some of you have mentioned about the shift fork bending or breaking being the issue. I have devised a new plan that my wife is not thrilled about. I am going to pick up another wheel horse to use around the property while I teach myself to rebuild the 8 speed in my current tractor lol. 2 Share this post Link to post Share on other sites
adsm08 3,339 #14 Posted May 7 33 minutes ago, Dcarr4510 said: I drained the oil in the transaxle. Did have a little bit of milkyness to it. Shift boot was not damaged, but scooted its way up the shift lever. Guessing thats how moisture got in. My guess is what some of you have mentioned about the shift fork bending or breaking being the issue. I have devised a new plan that my wife is not thrilled about. I am going to pick up another wheel horse to use around the property while I teach myself to rebuild the 8 speed in my current tractor lol. It's pretty easy. As counter-intuitive as it sounds, when you open it have the shallow side down. Share this post Link to post Share on other sites
SylvanLakeWH 28,602 #15 Posted May 8 Good to have another Michigander!!! 1 Share this post Link to post Share on other sites
Dcarr4510 8 #16 Posted May 8 9 hours ago, adsm08 said: It's pretty easy. As counter-intuitive as it sounds, when you open it have the shallow side down. Thank you for this. I would have definitely done the opposite lol. Share this post Link to post Share on other sites
rjg854 12,251 #17 Posted May 8 Seeing your plan is to open up the tranny, flush it really good and a couple of times, old gear oil smells pretty bad. and it makes cleaning up your parts easier. 1 Share this post Link to post Share on other sites
adsm08 3,339 #18 Posted May 8 11 hours ago, Dcarr4510 said: Thank you for this. I would have definitely done the opposite lol. I did it that way because I couldn't get the drain plug out, and it made more sense that that was the side everything should stay in. It caused some other issues because the fork and rail assemblies are in the shallow side and the cluster gear wants to stay with them. Share this post Link to post Share on other sites
Dcarr4510 8 #19 Posted May 10 (edited) On 5/8/2025 at 8:54 AM, rjg854 said: Seeing your plan is to open up the tranny, flush it really good and a couple of times, old gear oil smells pretty bad. and it makes cleaning up your parts easier. Will do. Looks like diesel should be okay for this? On 5/8/2025 at 5:28 PM, adsm08 said: I did it that way because I couldn't get the drain plug out, and it made more sense that that was the side everything should stay in. It caused some other issues because the fork and rail assemblies are in the shallow side and the cluster gear wants to stay with them. Good to know. Any help so I dont dump the internals all over the floor is much appreciated. I did end up getting a C120 with the Kohler to cover my yard needs until I fix this trans issue. Came with a blade as well. Edited May 10 by Dcarr4510 4 Share this post Link to post Share on other sites
Teddo 56 #20 Posted June 16 Dcarr, I like your way of thinking. Just get another tractor while you're working on the other one...then when you get it fixed you can work on the 2nd one! I have just gathered up the parts I think I'll need to fix what I think is a bent hi-lo shift fork. I'm hoping all the bearings are good. None of the current seals are leaking but they will get replaced. I tried a suggestion that maybe a washer under the roll pin might raise the gears and help shifting but that was not the problem. Everytime I try and shift from hi to lo, I can barely get it back into hi. So I have finally gotten it back into "hi" and I'm not messing with it anymore. I think it needs to come apart. Fluid inside looks very clean. No leaks but... Before I take the time to put this new fork in I wanted to ask if anyone knows where the pics are of a new shift fork that has been beefed up. I'm new to the forum and am still trying to find my way around but I've seen pics somewhere of a fork someone worked on. Now would be the time. Thanks. 1 Share this post Link to post Share on other sites
squonk 43,943 #21 Posted June 16 That rebuilt transmission is probably owned by @Jake Kuhn Share this post Link to post Share on other sites
Teddo 56 #22 Posted July 7 Dcarr4510. I just finished repairing a tranny on a C-121. It was a broken shift fork. If you are "handy" and tend to repair everything you see, this should be a fun project. Stevasaurus's videos and information from everyone can walk you through it. It's not hard. Certain aspects can be a pain, though. My hardest part was GETTING to the transmission: getting the hubs off. PITA if you know what I mean. Use a puller that grabs behind the entire hub, not just the face...or you will be buying hubs. The detent ball installation was easy for me. I thought ahead and had a flat cardboard box under the area I was woring on so those little critters would be rolling under some bench. Pencil magnet for setting them in and patience. The transmissions really can be fun...once the hubs are off. Lots of help here. Share this post Link to post Share on other sites
