Lcfman 4 #1 Posted May 1, 2025 I have a 310-8 I bought new in 1987. It’s been and still is a great piece of equipment. The only thing I have replaced is a carburetor a couple years ago and the mower deck belts(the main drive belt last year, can you believe the belts lasted that long). My question is there a direct 10 or 12 horsepower motor replacement. Share this post Link to post Share on other sites
kpinnc 16,515 #2 Posted May 1, 2025 7 minutes ago, Lcfman said: is there a direct 10 or 12 horsepower motor replacement. Any Magnum 10-16hp is a direct replacement. Many engines will work, but have varying degrees of modification involved. Share this post Link to post Share on other sites
Ed Kennell 44,089 #3 Posted May 1, 2025 (edited) Why are you looking for a replacement? Your tractor should have the Kohler Magnim 10 engine model number M10s-46152. The M10,12,14, and 16 should fit if from a gear drive. If from a hydro, you will need to change the pulley. Also may need to alter the belt guard for the 14 and 16. Edited May 1, 2025 by Ed Kennell Share this post Link to post Share on other sites
Lcfman 4 #4 Posted May 1, 2025 The current and original engine is the Kohler 8 hp and I was looking to upgrade with a little more power. Share this post Link to post Share on other sites
pfrederi 19,463 #5 Posted May 1, 2025 (edited) 49 minutes ago, Lcfman said: The current and original engine is the Kohler 8 hp and I was looking to upgrade with a little more power. If original your tractor is a 308-8 and gas tank is integral to the engine. Bigger engines you will have to get a fuel tank (under seat type) Edited May 1, 2025 by pfrederi Share this post Link to post Share on other sites
Ed Kennell 44,089 #6 Posted May 1, 2025 Can you post pictures of the tractors model plate and engine plate so we can determine if it is a 308-8 or a 310-8 Share this post Link to post Share on other sites
