JCD 76 #1 Posted April 30 My tractor has a double bagger on it but I need to remove it to replace the gas tank grommet. I haven't found a manual that shows how to do it. I tried taking out the cotter pins but couldn't get anything to move, didn't force it as I didn't want to break anything. I found a post that said all you need is a 7/16 wrench and everything else clips or slips in place but I could use a bit more info. Could anyone post a quick how to or link a vid. my bagger set up looks just like this one, copied as mine is 4hrs away atm. Thanks, Jim Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,437 #2 Posted April 30 This one? Share this post Link to post Share on other sites
JCD 76 #3 Posted May 1 Yes Sir, thank you very much. Jim Share this post Link to post Share on other sites
Lee1977 7,185 #4 Posted May 1 If you are going to remove the gas tank to replace the grommet. There are two bolts under the fender holding the gas tank and also two more under the tank supports one each side up in to the bottom of the tank. It's a good idea to make sure the inside of the tank is clean. Share this post Link to post Share on other sites
JCD 76 #5 Posted May 1 Thank you Lee, I'll get that grommet in one way or another, you guys have a good one. Jim Share this post Link to post Share on other sites
