Nuguy2 0 #1 Posted April 29 Just doing some necessary maintenance. Need some information on repair/replacement of the Choke Cable (OEM). The cable to the choke on the carburetor is very hard to operate. Going to try some lubrication and such. Wondering if there is a source for something newer? Thanks Agiin!! Share this post Link to post Share on other sites
Racinbob 12,234 #2 Posted April 29 Identical to my 76 you can snip the z-bend off and remove the cable. Carefully release the lever end by gently opening the squeezed part. Steel wool the cable and lubricate. Get some lube inside the tube. You can get cable lubricator gizmos but I just use spray with one of those little red nozzles. It's a good idea to slide the wire back in and out. It will help get some of the gunky out. After a few times put it back together and it will be smooth. Be careful squeezing the crimpy thing on the control so you don't get it too tight. Lube the pivot points. 1 Share this post Link to post Share on other sites
peter lena 9,452 #3 Posted April 29 @ Nuguy 2 , like a penetrating oil , 3-1 can is good, also aerosol, maintain my cables with super lube hydraulic oil , https://www.amazon.com/Super-Lube-52004-Lightweight-Translucent/dp/B00175VGUA/ref=asc_df_B00175VGUA?mcid=09c8adc215b03a4a85e5645c583208c5&tag=hyprod-20&linkCode=df0&hvadid=693071814229&hvpos=&hvnetw=g&hvrand=12216612154201406057&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9191633&hvtargid=pla-583247953159&th=1, shop around for price , local H/W STORE , temp range is amazing , have also added spring pull to my cables , so any movements are always assisted , pete Share this post Link to post Share on other sites
