John2189 546 #1 Posted April 29 What is the procedure to troubleshoot? Does the voltage normally go bad? Wiring looks good. John Share this post Link to post Share on other sites
953 nut 60,541 #2 Posted April 29 First thing to do is clean and tighten ALL electrical connections including grounds. Test the voltage regulator by using a multimeter set on DC 20 volt setting and you should have 12+ volts on the "B+" terminal of the regulator with the engine not running but the key switch ON. If you don't have 12+ volts then go to the R terminal of the ignition switch to see if you have voltage there. If there is voltage at the voltage regulator "B+" terminal then start the engine and see if there has been any change in the voltage. Next place to check would be the two AC terminals on the voltage regulator. With the engine running at about half throttle and your multimeter on the AC Volts scale you should read about 35 AC voltage between the two AC terminals. 1 1 Share this post Link to post Share on other sites
John2189 546 #3 Posted April 29 12 minutes ago, 953 nut said: First thing to do is clean and tighten ALL electrical connections including grounds. Test the voltage regulator by using a multimeter set on DC 20 volt setting and you should have 12+ volts on the "B+" terminal of the regulator with the engine not running but the key switch ON. If you don't have 12+ volts then go to the R terminal of the ignition switch to see if you have voltage there. If there is voltage at the voltage regulator "B+" terminal then start the engine and see if there has been any change in the voltage. Next place to check would be the two AC terminals on the voltage regulator. With the engine running at about half throttle and your multimeter on the AC Volts scale you should read about 35 AC voltage between the two AC terminals. Thanks Share this post Link to post Share on other sites
