AHS 1,612 #1 Posted April 27, 2025 i did it again! I USUALLY write on the inside of the mule drive which one it fits…( 42”, 48”). So, the belt numbers have been wore off. What’s the belt length of a 42” 108834? whats the belt length of a 48” 94-2501? I don’t know if i have the correct belt #’s for their sizes. Thank you!! Share this post Link to post Share on other sites
peter lena 9,782 #2 Posted April 27, 2025 @AHS just a suggestion , how easily / quietly do all related pulleys move ? lubrication failure is a regular thing with related pulleys , also very easy to to correct / eliminate . polyurea grease , pete 1 Share this post Link to post Share on other sites
Lee1977 7,578 #3 Posted April 27, 2025 95-2501 is 1/2" x 103" it will work on both the 48" and 42" side discharge mule drive belts. I have 1/2" x 103 blue belt from Tractor Supply on a couple of my decks. Not sure what the 108834 belt is. They kept up grading numbers over the years so it could be the same.. 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,017 #4 Posted April 27, 2025 2 hours ago, AHS said: i did it again! I USUALLY write on the inside of the mule drive which one it fits…( 42”, 48”). So, the belt numbers have been wore off. What’s the belt length of a 42” 108834? -------------- Drive belt 108834 (1/2" x 98")------------42" rear discharge mowers What's the belt length of a 48” 94-2501? ------------- Drive belt 102742 replaced by 94-2501 (1/2" x 103") ----------- This belt also drives some of the 42" side discharge mowers. I don’t know if i have the correct belt #’s for their sizes. Thank you!! If you search our files using a belt number all the file descriptions that contain the number will show up. Often you can view the info without downloading anything. The reason for adding that info is there are mistakes in the belt charts Wheel Horse published which reminds me that task needs to be completed. 1 Share this post Link to post Share on other sites
AHS 1,612 #5 Posted April 27, 2025 5 hours ago, gwest_ca said: If you search our files using a belt number all the file descriptions that contain the number will show up. Often you can view the info without downloading anything. The reason for adding that info is there are mistakes in the belt charts Wheel Horse published which reminds me that task needs to be completed. Ok, good to know! I had a feeling that they were similar. Thank you! Share this post Link to post Share on other sites
AHS 1,612 #6 Posted April 27, 2025 6 hours ago, peter lena said: @AHS just a suggestion , how easily / quietly do all related pulleys move ? lubrication failure is a regular thing with related pulleys , also very easy to to correct / eliminate . polyurea grease , pete Oh ya, the decks are kept well greased! Share this post Link to post Share on other sites
