perry 82 #1 Posted February 13, 2008 this was on a snow plow axle hitch that i bought last summer. i was told that it came from a D series tractor . at first i thought it was a spacer like the other styles i have. but this just wont work as a hitch-axle spacer. the plow blade also has 2 lift areas on the lift bracket. one is a hole and the other is a slot. when i mounted the blade up tonight i hooked the lift arm into the slotted hole. figured that was to give it a little freedom and not to have constant pressure on it from the hydro . Share this post Link to post Share on other sites
pond195520032003 27 #2 Posted February 14, 2008 Perry, from what i have seen of these, i believe it goes above the rear axle on the hitch, kind of like an alignement spacer will check and post pics if i run accross it again :thumbs: Share this post Link to post Share on other sites
