stvski80085 279 #1 Posted April 21, 2025 I need blades for this deck. Right side discharge with two 12inch blades and one 14. Looking for a new set if I can find them. The kit was 101335 but many of those have same size blades. Any idea's? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,017 #2 Posted April 21, 2025 https://www.partstree.com/parts/toro-101335/ 1 Share this post Link to post Share on other sites
stvski80085 279 #3 Posted April 22, 2025 18 hours ago, gwest_ca said: https://www.partstree.com/parts/toro-101335/ Thanks. Not sure how I missed it. I found some others but they all looked the same length so I was confused a bit. Wish they had some gator blades for this thing. Little pricey. Share this post Link to post Share on other sites
peter lena 9,782 #4 Posted April 22, 2025 @stvski80085 done a number of decks , if you are replacing blades , chances are the spindle bearings are rough and noisy , bearing change out and also , vital opportunity , to re grease those new bearings , probably 6203( 3/4 ) 2RSC3 , they come with wide bearing side shields . making a very easy removal , clean out , re grease with lucas XTRA HD green chassis grease why ? polyurea rated also 550 deg flash point , the heat and drag stress on spindles is what eats them alive , original grease , is unknown ,and minimal, why chance it ? since doing my decks and related same mule drive bearings , have had zero issues , no noise or whyining , also did my pto needle bearing , replace outer sealed bearing , ( NAPA ) , REALLY NOT A BAD JOB , grease is at Walmart $ 8 , my decks spin BY HAND at mule drive down belt to deck . just a suggestion , pete Share this post Link to post Share on other sites
stvski80085 279 #5 Posted April 22, 2025 Peter, I have rebuilt and replaced everything on the deck except the blades. All new bearings, idler pulley, belt ect. It runs well just the blades are so old even after sharpening I think the old owner put the rear discharge blades on it. It doesn't throw much out the side. Thanks though. Steve 1 Share this post Link to post Share on other sites
76c12091520h 4,127 #6 Posted April 22, 2025 Several sets in stock. Pm me or call / text during normal business hours. Way cheaper than current OEM cost. Share this post Link to post Share on other sites
stvski80085 279 #7 Posted April 23, 2025 4 hours ago, 76c12091520h said: Several sets in stock. Pm me or call / text during normal business hours. Way cheaper than current OEM cost. Nice. Will do. Share this post Link to post Share on other sites
