gloubi 2 #1 Posted April 21, 2025 Hi everybody , I have open my C160 gearbox because one key on an axe has broken . But i need to change de ball bearings (1 1/2 x 2 1/2 x 1/2) on wheel axes and the seals . But i can't find these balls bearing in France . Is anybobody to send me a seller for these parts ? Thank's for all Share this post Link to post Share on other sites
ri702bill 12,980 #2 Posted April 21, 2025 Welcome!! Check out WheelHorsePartsandMore. Lowell has various 4 speed and 8 speed rebuilding kits. You can find him in the Vendors section... 1 Share this post Link to post Share on other sites
953 nut 69,143 #3 Posted April 21, 2025 Here is a link to the seller of these bearings. He also can provide all of the other bearings and seals you might need in addition to the gasket and the rubber boot for the shift lever. https://wheelhorsepartsandmore.com/product/1533-bearings-qty-2/ https://wheelhorsepartsandmore.com/product-category/manual-transmissions/ 2 Share this post Link to post Share on other sites
WHX?? 58,060 #4 Posted April 21, 2025 Gloubi Common parts on this side of the pond and we often take it for granted that they are readily available. Share this post Link to post Share on other sites
gloubi 2 #5 Posted April 21, 2025 Thank's for your help . I send a message to wheelhorsepartsandmore . I hope they send parts in France 2 Share this post Link to post Share on other sites
sjoemie himself 3,186 #6 Posted April 27, 2025 On 4/21/2025 at 3:42 PM, gloubi said: I hope they send parts in France If that is not an option or it gets too expensive let us know. Most of the time if you have the outside diameter, the inside diameter and the width of the bearing you can find what you need. I've had good luck finding bearings I need through the website of SKF, a well known bearing manufacturer. Greetings from the Netherlands, Mark 2 Share this post Link to post Share on other sites
