Cjwv1975 117 #1 Posted April 19, 2025 Any good ideas on how to replace tiller tines. Mine are pretty shot. I know Toro still sells replacements and AZ tractors had a kit but hate to spend that much on something used a few times a yr. Thanks Share this post Link to post Share on other sites
daveoman1966 3,885 #2 Posted April 19, 2025 Consider this: If tines cost you $300...and last for 15 years.... that's only $20/year. Surely, you (and I) have blown up $20 on MANY useless things... Or, maybe you'd rather use a pick and shovel. (lol). 2 1 1 Share this post Link to post Share on other sites
Cjwv1975 117 #3 Posted April 19, 2025 16 minutes ago, daveoman1966 said: Consider this: If tines cost you $300...and last for 15 years.... that's only $20/year. Surely, you (and I) have blown up $20 on MANY useless things... Or, maybe you'd rather use a pick and shovel. (lol). Ive got an old Snapper self propelled Ive used before I got this tiller attachment. Ive spent well over that on my WH so yeah I get it but just looking and hoping for a cheaper alternative lol. Share this post Link to post Share on other sites
pfrederi 21,342 #4 Posted April 19, 2025 If they are not entirely worn lay a couple beads of weld on the leading edge.. Never tried it my self but remember some discussion from TroyBilt users who did it 2 Share this post Link to post Share on other sites
oliver2-44 11,847 #5 Posted April 19, 2025 If you have a scrap piece of flat copper or brass you can use it as a backer" when you try to weld the tines up. Steel does not stick to brass or copper. Consider it good welding practice. doesn't mater what ir t looks like, because your going to grind it to a square flat profile anyway. 1 1 Share this post Link to post Share on other sites
kpinnc 19,107 #6 Posted April 20, 2025 Mine has a set of Ford tine blades on it. They are exactly the same tines that Wheel Horse used. Bolted right up onto the same holes. My point is that you shouldn't limit yourself to the Wheel Horse name brand. 20 years ago I would not have said this, but nowadays it's getting harder to find this stuff. As with many tractors of the same time period, there were alot of different brands that used the same vendors for some parts. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,557 #7 Posted April 20, 2025 Often wonder if these could be bolted on to the Wheel Horse tiller. They must be a popular item if these folks in Ontario Canada carry them. They have the original part numbers listed which is handy for more searching with dimensions. There can not be many companies still manufacturing them. Set https://www.bantasaw.com/catalog/viewproduct.asp?i=&p=8531 Left https://www.bantasaw.com/catalog/viewproduct.asp?i=&p=4123 Right https://www.bantasaw.com/catalog/viewproduct.asp?i=&p=4124 Left https://www.bantasaw.com/catalog/viewproduct.asp?i=&p=5365 Right https://www.bantasaw.com/catalog/viewproduct.asp?i=&p=5366 Share this post Link to post Share on other sites
