Mike'sHorseBarn 3,392 #1 Posted April 18, 2025 Is this normal? Both back axles move the same distance at the same time. I was gonna do seals the whole way around, but if I need to pull the trans apart, I'd rather know now. 20250417_202505.mp4 2 Share this post Link to post Share on other sites
ebinmaine 76,392 #2 Posted April 18, 2025 (edited) In / out. Is fine. Up n down or fore n aft is not. Edited April 19, 2025 by ebinmaine 4 1 Share this post Link to post Share on other sites
kpinnc 16,479 #3 Posted April 19, 2025 4 hours ago, ebinmaine said: In / out. Is fine. Up n down or fore n aft is not. 2 Share this post Link to post Share on other sites
stevasaurus 23,533 #4 Posted April 19, 2025 Nothing wrong there !! That is just the slack between the 2 axles and the roll pins or "C" clips. 2 1 Share this post Link to post Share on other sites
Tomato 33 #5 Posted April 25, 2025 Shouldn't cause any problems. I have seen where a guy added thrust washers between the axle gears and differential ends. But as the others have already said this play shouldn't cause any problems. Share this post Link to post Share on other sites
