Mickwhitt 5,259 #1 Posted April 18, 2025 Thought this might be of interest. 4 6 1 Share this post Link to post Share on other sites
ebinmaine 80,743 #2 Posted April 18, 2025 Quite a rig!! 1 Share this post Link to post Share on other sites
Mickwhitt 5,259 #3 Posted April 18, 2025 Apparently the tractor was scratch built as none of the 9 originally built have survived. You boys have purdy big fields out there to need such equipment. 2 1 Share this post Link to post Share on other sites
ebinmaine 80,743 #4 Posted April 18, 2025 6 minutes ago, Mickwhitt said: Apparently the tractor was scratch built as none of the 9 originally built have survived. You boys have purdy big fields out there to need such equipment. Yepp. I've never seen em. They just go rolling on and on and on for days! Share this post Link to post Share on other sites
Achto 32,748 #5 Posted April 18, 2025 51 minutes ago, Mickwhitt said: Apparently the tractor was scratch built as none of the 9 originally built have survived. I've had the opportunity to see Kory Anderson's 150hp Case. He is a good down to earth guy that built a very impressive machine, In Case you did not find the build video. 3 2 Share this post Link to post Share on other sites
WHX?? 58,156 #6 Posted April 18, 2025 31 minutes ago, Achto said: I've had the opportunity to see Kory Anderson's 150hp Case. Mick ... old news this side of the pond. You oughta see it go on a pulling track. Show we go to every year brought it in two years in a row. Costs like 75k to get it not including transportation cost. 4 7 Share this post Link to post Share on other sites
kpinnc 18,969 #7 Posted April 19, 2025 I think we found the "wide rear Wednesday" champion! 51 moldboards? That is some serious ground engaging power!!! 1 1 3 Share this post Link to post Share on other sites
Mickwhitt 5,259 #8 Posted April 19, 2025 Someone posted it on a model engineering website over here, just in case anyone wanted to build a scale replica. The engine would be ok, but imaging making all the plows lol. 2 Share this post Link to post Share on other sites
Streetrodchev 1,178 #9 Posted April 19, 2025 I made the trip out to their home show at Andover, SD in 2021. Then in 2023 and 2024 it came to one of my local shows at Burnett, WI IMG_9410.mov 5 Share this post Link to post Share on other sites
Streetrodchev 1,178 #10 Posted April 19, 2025 IMG_9288.mov 5 3 Share this post Link to post Share on other sites
WHX?? 58,156 #11 Posted April 19, 2025 Short story is they found the blueprints in a basement and he built it off of that. He had to buy a foundry and a machine shop to do it. Still boggles the mind that he made all of the parts for a one off machine. 6 hours ago, Mickwhitt said: build a scale replica. What would be cool is if they made a plastic model kit of it. Will haveta get a t shirt for ya Mick ... bet you would be the only one in the UK to have one! 1 2 Share this post Link to post Share on other sites
Streetrodchev 1,178 #12 Posted April 21, 2025 (edited) Case still has the blueprints, Kory went there to copy them, then spent a lot of time converting it to cad, before starting the actual build. There was one boiler remaining (in Arizona) that a farmer was using as a water tank, it was purchased and is now in Andover, SD. The serial number was taken from that original boiler and is now on the new 150. IMG_9423.mov Edited April 21, 2025 by Streetrodchev 1 3 1 Share this post Link to post Share on other sites
OoPEZoO 609 #13 Posted April 21, 2025 Wow....thanks for sharing all of that 2 Share this post Link to post Share on other sites
Beap52 2,497 #14 Posted May 5, 2025 More times than not when I worked for farmers, they provided lunch. WOW! just think about feeding that bunch! 2 Share this post Link to post Share on other sites
