HyperPete 913 #1 Posted April 18, 2025 I'm mid-attempted oil change on this hydro. I was able to remove the 1/4" hex drive bolt on front of the "hump", but the one behind the hump stripped. I'm not sure that's a drain anyway. I was under the impression it uses 10W30 or 10W40, but it is filled with ATF. The same for my ARK500 Series FEL. On that, I followed the instructions to 'purge' the fluid prior to a refill, but was only able to drain about 3 Qt. After refilling with 10W30 and burping it a few times, I jacked the front of the tractor up for the transmission service. Pure ATF overflowed out of the vent at the top of the right FEL tower. So, #1) Do I just continue using ATF in the transmission or is there another drain plug I'm missing? Where is the fill? #2) what do I do about the FEL fluid? Will the ATF & motor oil mix & just give me a high detergent motor oil mix? Should I use it for a bit, then do another oil change with 10W30? I'll create a link in my FEL thread pointing here. Thanks! 1 Share this post Link to post Share on other sites
squonk 46,133 #2 Posted April 18, 2025 73 was the changeover to motor oil from ATF. some came with the red stuff and some had motor oil. Keep the ATF. Use Dexron / Mercon 2 Share this post Link to post Share on other sites
HyperPete 913 #3 Posted April 18, 2025 I used Dexron 3 in the hydro, thank you for the guidance! Also a Wix 51410. Share this post Link to post Share on other sites
kpinnc 17,922 #4 Posted April 19, 2025 I run ATF in my Sundstrand hydros. Having been inside one with motor oil and one with ATF, I will stick with the latter. 2 Share this post Link to post Share on other sites
ebinmaine 78,320 #5 Posted April 19, 2025 17 hours ago, HyperPete said: FEL thread Can you link that thread here too? This will be something I need to do soon. Share this post Link to post Share on other sites
gt14rider 1,158 #6 Posted April 19, 2025 Hyperpete, you should not mix atf and 10w30, you my have contaminated your atf, I would not run, drain as much as you can. May have to flush system. Share this post Link to post Share on other sites
HyperPete 913 #7 Posted April 20, 2025 (edited) 2 hours ago, gt14rider said: Hyperpete, you should not mix atf and 10w30, you my have contaminated your atf, I would not run, drain as much as you can. May have to flush system. This is the info I am seeking. How do I flush the system? At this point there is undoubtedly more 10W30 than ATF in the system. Edited April 20, 2025 by HyperPete Share this post Link to post Share on other sites
oliver2-44 11,401 #8 Posted April 20, 2025 2 hours ago, HyperPete said: How do I flush the system? If your referring to the Sundstrand hydro, there is not a way to fully drain/ flush it. About the best you can do is change the oil, run it a short time repeat, repeat Share this post Link to post Share on other sites
gt14rider 1,158 #9 Posted April 20, 2025 So you put 10w30 in the FEL , I don't have a FEL but you would need to drain the fluid reservoir, find the lowest line, try to drain as much as you can. Refill with atf and repeat. Hopefully someone with more experience on the FEL will chime in. But I would not run it to much till you get it drained. Good luck. Share this post Link to post Share on other sites
HyperPete 913 #10 Posted April 20, 2025 I will refill the Ark 508 QM FEL with 10W30 as that is what it listed in the manual. Had I known it would not drain thoroughly, I would have stuck with ATF, but at this point, I have committed to the motor oil.. I guess, since I have done it once, I'll just do it again. As far as the Sundstrand, thats done. Drained and refilled and acting better. 1 Share this post Link to post Share on other sites
