Andy G 8 #1 Posted April 18, 2025 Found a ‘66 1046 rolling frame for dirt cheap. I know they had a different sized engine in them, but does that make it difficult to find an engine that fits? thanks! Share this post Link to post Share on other sites
SylvanLakeWH 31,428 #2 Posted April 18, 2025 I'm doing a predator swap on something "similar" right now... Share this post Link to post Share on other sites
Achto 31,814 #3 Posted April 18, 2025 (edited) 6 hours ago, Andy G said: I know they had a different sized engine in them, but does that make it difficult to find an engine that fits? It would have had a 10hp Kohler with short oil pan, or left over engines from the 1965 models. Not too difficult to find. Edited April 18, 2025 by Achto Share this post Link to post Share on other sites
squonk 46,568 #4 Posted April 18, 2025 Drop a K181 in it and ride 1 Share this post Link to post Share on other sites
953 nut 66,100 #5 Posted April 18, 2025 (edited) What engine you use will depend on your intended use for the . If you want to restore it to original you will wand a Kohler K-241 AS, if it is going to be your ride around and have fun with it tractor then anything that fits will work. There are lots of threads on here about engine swaps. The 1965 and 1966 ten horsepower Wheel Horses came with a Kohler K-241 AS engine, which is a bit shorter than the "Large base" Kohler engines. The thread below will show you what to look for. Edited April 18, 2025 by 953 nut fat finger 1 1 Share this post Link to post Share on other sites
WHX?? 56,598 #6 Posted April 18, 2025 Cub motors with the short pan work with a little notching in the frame. Same tractor as a 1045 but with the "newer" seat pan. A 1046 is somewhat of a rare one. Don't see them come up here often. I don't think they made a lot of them. Like Dan said just using up motors from '65 and the trend was going to long frames and the soon to come six speeds. Shouldn't be too hard to find the correct Kohler. 1 1 Share this post Link to post Share on other sites
