Retired Army 1 #1 Posted April 15, 2025 Wondering the cause of my slow speed. Seems to be losing more speed especially on hills. Ideas? 1 Share this post Link to post Share on other sites
rmaynard 17,494 #2 Posted April 15, 2025 (edited) Check your fluid level, and maybe replace your hydro filter. Correct filter is either an OEM filter 79-5270 or WIX 51410. Edited April 15, 2025 by rmaynard 1 1 Share this post Link to post Share on other sites
nylyon-(Admin) 9,039 #3 Posted April 15, 2025 Also check for grass accumulation on the rear cam plate Share this post Link to post Share on other sites
lynnmor 8,970 #4 Posted April 15, 2025 Condition of belt? Condition of idler pulley and its bearing? Is the transmission pulley tight on the shaft. Share this post Link to post Share on other sites
oliver2-44 11,661 #5 Posted April 15, 2025 (edited) Tell us a little about your self and you tractor. In your profile I see it says you have a hydro 15 hp. but that doesn't tell us enough about it. The 520 was originally 20hp, so does it have a different 15hp engine? Edited April 15, 2025 by oliver2-44 Share this post Link to post Share on other sites
Wayne0 1,609 #7 Posted April 15, 2025 (edited) Adjust the cam plate on the transmission and see if that's the problem. Had the same issue with one of mine. .BTW Edited April 15, 2025 by Wayne0 1 Share this post Link to post Share on other sites
953 nut 68,157 #8 Posted April 15, 2025 If you 520 has been in storage for a while take a look under the plate where the shift lever is located. I had chipmunks nested there and the debris left behind prevented the shift lever from moving all the way. 1 Share this post Link to post Share on other sites
Pullstart 71,004 #10 Posted April 16, 2025 and thank you for your service! 1 Share this post Link to post Share on other sites
