Retired Army
520-H 3 mph top speed
Retired Army
Wondering the cause of my slow speed. Seems to be losing more speed especially on hills. Ideas?
  • Thanks 1
rmaynard
Check your fluid level, and maybe replace your hydro filter. Correct filter is either an OEM filter 79-5270 or WIX 51410.
:WRS:
Edited by rmaynard
  • Excellent 1
nylyon
Also check for grass accumulation on the rear cam plate
lynnmor
Condition of belt?  Condition of idler pulley and its bearing?  Is the transmission pulley tight on the shaft.
oliver2-44
:text-welcomeconfetti:
Tell us a little about your self and you tractor.
In your profile I see it says you have a hydro 15 hp. but that doesn't tell us enough about it.
The 520 was originally 20hp, so does it have a different 15hp engine?
Edited by oliver2-44
parsonsponyz
Wayne0
Adjust the cam plate on the transmission and see if that's the problem. Had the same issue with one of mine.
.BTW :text-welcomeconfetti:
Edited by Wayne0
953 nut
:WRS:
If you 520 has been in storage for a while take a look under the plate where the shift lever is located. I had chipmunks nested there and the debris left behind prevented the shift lever from moving all the way.
Achto
:WRS:
Pullstart
:text-welcomeconfetti: and thank you for your service!  :flags-waveusa:
SylvanLakeWH
