HyperPete 881 #1 Posted April 13 I have a line on a NOS rototiller attachment. It's a “Vertical Shaft” B Series Tiller. How difficult will it be to convert it for use with my 414-8? (Please say easy!) Share this post Link to post Share on other sites
HyperPete 881 #2 Posted April 13 Tillers are for a B115 - B165. What's the basic difference? Just mounting? Pulleys? Belts? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,595 #3 Posted April 13 Each of these links pertain to the B-Series tiller 4 files for tiller model 07-30TL01 https://www.wheelhorseforum.com/search/?&q=07-30tl01&type=downloads_file&search_and_or=or&sortby=relevancy 2 files for tiller model 07-30TL02 https://www.wheelhorseforum.com/search/?q=07-30tl02&quick=1&type=downloads_file The 414-8 requires a 07-36TL03 or similar model. You can compare the parts and note that one is 30" wide and the other 36" wide Share this post Link to post Share on other sites
HyperPete 881 #4 Posted April 13 (edited) Thank you! It's a TL01, BTW. Edited April 13 by HyperPete Share this post Link to post Share on other sites
HyperPete 881 #5 Posted April 14 4 hours ago, gwest_ca said: The 414-8 requires a 07-36TL03 or similar model. You can compare the parts and note that one is 30" wide and the other 36" wide So, are you saying that the TL01 can't be easily converted for use with my 414-8? Sorry, I'm dense. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,595 #6 Posted April 14 5 hours ago, HyperPete said: So, are you saying that the TL01 can't be easily converted for use with my 414-8? Sorry, I'm dense. Not saying that at all. I have never seen either one of them. The 30" tiller is for a tractor with a vertical engine crankshaft. You need the 36" tiller for a tractor with a horizontal engine crankshaft. After looking at the illustrated parts lists for both it is not a challenge I would attempt. If it was done you would likely tear it up on the 2nd pass through the garden. Sorry 1 Share this post Link to post Share on other sites
HyperPete 881 #7 Posted April 14 Thank you. It's a shame, and disappointing because I can't find a decent tiller, but I sincerely appreciate your help. Share this post Link to post Share on other sites
HyperPete 881 #8 Posted April 16 Will a Rototiller, model 79370 match my 414-8? It came off a 314. Share this post Link to post Share on other sites
HyperPete 881 #9 Posted April 17 (edited) On 4/13/2025 at 5:11 PM, HyperPete said: I have a line on a NOS rototiller attachment. It's a “Vertical Shaft” B Series Tiller. These tillers will be at the big show, should anyone be interested in them. https://www.facebook.com/share/1BE1ZDZ3f8/?mibextid=kL3p88 Edited April 17 by HyperPete Share this post Link to post Share on other sites
c-series don 10,258 #10 Posted April 18 @HyperPete if it worked on a 314, it will work on your 414. 1 Share this post Link to post Share on other sites
HyperPete 881 #11 Posted April 18 3 hours ago, c-series don said: @HyperPete if it worked on a 314, it will work on your 414. Thanks, I'm picking it up on Tuesday. Tough finding good tillers it seems. 1 Share this post Link to post Share on other sites
