Similar Content
By classiccat
New member ...and another old-Iron guy here...with my 1st Wheel Horse tractor.
I was looking for something mainly for pulling an old aluminum boat (18' starcraft) around the property.
Capability to mow and haul yard waste would be a bonus.
2 weeks ago, a C85 showed-up on CL for a song.
He couldn't start it for me and it didn't take me long to figure out why...
This will be a running thread / rolling-restoration as I bring her back to her original, Black-Hood glory!
(DISCLAIMER: I'm an engine-wrencher ...I have the tendency to leave my foot off of the project's gas when the engine starts drinking it!)
By Mr Sweep
My tractor wouldn't start. So i jump sarted it with my van. I attached cables jumped on tractor and started right up. I detached cables put c85 in gear and a minute later backfires and quits. Checked oil gear oil gas all good. Battery reads 10.8 voltz. repeated this process 4 times to drive c85 back to my garage. Anyone had this before. Oh and its a new battery last year. I looked for a short or loose connection and didn't find anything???
By JackHorse
Having a hard time justifying $300 to rebuild the spindles and replace pulleys on my deck. The deck is a (i believe) 05-36MS01 on my 1982 C85. I found these kits on Pat's and was wondering if anyone had tried to adapt them to a deck like mine? Thanks
By JoeM
Started another project this fall, I decided to install a 10 HP Chinese Diesel in a rescued C85. I worked a good price from Carroll Stream this spring on an engine and when I picked up the C85 in WV, I thought that would make a good fit. And like everything else I do, it got a little carried away!
Frist thought was making a worker, now slowly turning into a show pony.
The C85 black hood worked well because of the vast room under the hood. I made up threaded mounting blocks from 3/8†bar stock for mounting the engine. The engine was too close to the top of the hood to allow the compression release to rotate; I made a new hood hinge and raised the hood 3/4â€. A small teak on the side of the hood using a bar clamp and that made enough room to clear the air cleaner.
Then came new paint, tires, a stack, (with chrome tip), a sleeve hitch and much more. It is now about 90% now. Hope to be done next month; I will shoot more pics when completed.
Thanks for looking.
Joe
