FLtractor 50 #1 Posted April 11 (edited) Are deck wheels universal as long as same size? As in I could replace my busted wheels eventually with any brand? Edited April 11 by FLtractor Share this post Link to post Share on other sites
ri702bill 9,348 #2 Posted April 11 OE Toro wheels are still avaivable - either thru Toro or some Fleabay sellers. But, OE is not cheap.... Share this post Link to post Share on other sites
FLtractor 50 #3 Posted April 11 1 hour ago, ri702bill said: OE Toro wheels are still avaivable - either thru Toro or some Fleabay sellers. But, OE is not cheap.... Right so if I wanted to save money go with an off brand… are there deck wheels out there that would work if I just found out what size dimensions I need? 1 1 Share this post Link to post Share on other sites
ri702bill 9,348 #4 Posted April 11 Lawnmower wheels may have a different axle length, even they are the proper diameter.... 1 Share this post Link to post Share on other sites
rjg854 12,153 #5 Posted April 11 What type of deck are you talking about? Early 60's rotary deck or the later models? Share this post Link to post Share on other sites
953 nut 59,767 #6 Posted April 11 Most of the time the deck wheel wear out the shoulder bolts as fast as the wheels, buy them as a set so everything fits right, most are 3/8 - 16 thread. 1 Share this post Link to post Share on other sites
FLtractor 50 #7 Posted April 11 3 hours ago, rjg854 said: What type of deck are you talking about? Early 60's rotary deck or the later models? 1966 856. Share this post Link to post Share on other sites
Handy Don 13,979 #8 Posted April 11 (edited) 1 hour ago, FLtractor said: 1966 856. That’s the tractor. At least 3 different styles of deck could work on it! Mounting the gage wheels differed on the different deck models over the years but the wheels stayed the same. When replacing, match the overall diameter, the bore (the diameter of the hole for the axle bolt), the length of the bore through the wheel, and any offset (where the end of the bore is closer or further from the centerline of the wheel. Look for wear on the axle bolts and replace if necessary. You might be tempted to use plastic-hub wheels thinking their load rating is adequate. My advice is to stick to steel-hub since there is a lot of side load on the wheels when making turns. Usually there are a couple of vendors at the Big Show selling deck wheels. Edited April 11 by Handy Don Share this post Link to post Share on other sites
rjg854 12,153 #9 Posted April 11 3 hours ago, FLtractor said: 1966 856. Is this the style deck you're posting about? Share this post Link to post Share on other sites
pfrederi 18,635 #10 Posted April 12 Let me a bit contrary here. I have used some cheap Arnold (big box store) Plastic wheel on some decks. Haven't broken one yet...I am sure they will wear out sooner than OEM...BUT I can replace them 3 times for the price of a Toro Wheel.... Share this post Link to post Share on other sites
rjg854 12,153 #11 Posted April 12 The ones on the above deck came from Tractor Supply. 1 Share this post Link to post Share on other sites
Handy Don 13,979 #13 Posted April 12 14 minutes ago, 76c12091520h said: Definitely the wider wheels on the heavier 3-blade, belt driven decks that came from 1968 (or 1969?) onward for long wheelbase tractors. They would not be on an 856. Share this post Link to post Share on other sites
