D_Mac 9,334 #1 Posted April 9, 2025 (edited) Ok I been looking around. I'm confused over the differences between these two models. Raider is gear drive and Charger hydro ? What years were they both produced and was the kohler vs tecumseh engines an option ? Could they be swapped without any modifications? Sounds like we are talking football teams Edited April 9, 2025 by D_Mac 1 Share this post Link to post Share on other sites
Achto 31,416 #2 Posted April 9, 2025 (edited) Raider is gear drive and Charger hydro ? Take a look through the master model list. Should answer a lot of this question. Usually not too hard to swap from a Tecumseh to a Kohler. Ignition switch is one thing that I know that needs to be changed. Edited April 9, 2025 by Achto 2 1 Share this post Link to post Share on other sites
D_Mac 9,334 #3 Posted April 9, 2025 Looking at a new project. Want to know what I'm getting into. 1 1 Share this post Link to post Share on other sites
D_Mac 9,334 #4 Posted April 9, 2025 Would things like that pto and drive belt guard all be the same ? Share this post Link to post Share on other sites
953 nut 64,858 #5 Posted April 9, 2025 37 minutes ago, D_Mac said: Want to know what I'm getting into. You won't know that until it is too late. 6 minutes ago, D_Mac said: Would things like that pto and drive belt guard all be the same ? All of the sheet metal except the shifter tunnel should be interchangeable. The IPL will show different part numbers on some pieces because the decal for the Hydro or 8 Speed would be included. The engine drive pulley will be larger on the Hydro but the PTO should be the same. Share this post Link to post Share on other sites
D_Mac 9,334 #6 Posted April 9, 2025 What I would be doing would be replacing the tecumseh 10hp with a Kohler 10hp. This kohler dosnt have the starter generator. Has the smaller starter on it. Picking it up soon. Photos to follow. Share this post Link to post Share on other sites
953 nut 64,858 #7 Posted April 9, 2025 If the Kohler has the breaker-less ignition system that came from the factory then this should be a simple plug and play swap. 1 Share this post Link to post Share on other sites
D_Mac 9,334 #8 Posted April 9, 2025 Well I will start a new thread since now it is home and I can what I got, and don't got for that matter. 1 Share this post Link to post Share on other sites
