bowtiebuster
broken head bolt
bowtiebuster
Ok, well as I took began tearing into my Kohler 10 today to clean it up and give it a once over, I broke a head bolt nearest the exhaust. It snapped just about a mill above the deck height. Attached is a pic of it.
What do you guys think? Has anyone else even snapped a bolt like this? Is it possible to drill out successfully?
Any info or insight into this depressing road block would be great!
Nicholas :scratchead:
Gene_S
Nicholas,
What I have done in the past was set the motor up on a bridgeport mill and center up as good as possible and drill it out. Then I would heli-coil the threads. Gota be as close as possible to center, use a short #3 center drill first. Most small engine shops will do this for a fee.
Good luck! It is fixable!
Thanks,
Gene
bowtieguy
Put a slightly larger nut over the stud...arc weld the stud to the inside of the nut.....when it cools off, you should be able to put a wrench on the nut and take it out....good luck.... :scratchead:
bowtiebuster
Thanks for the input guys. I dug into it today with drills and a tap. After probably over well over an hour of drilling from smaller to larger bits, and constantly needing to sharpen the bits, I got most of the bolt out and re-tapped it to the original size.
After I finished tapping, I put the motor back together and put it back on the Raider. The reason I took the motor off was because I thought it had no compression... At that time I didn't know about the ACR system and how it works... At least it gave me a chance to get to know a Kohler and clean it up a bit. lol
Thanks again,
Nicholas
Coadster32
Good job. Looks like it came out pretty square. :scratchead:
