stevebo-(Moderator) 8,600 #201 Posted May 23 Up for sale (delivered to the show) 1. 48” snow plow off a 418-8. Has the angle handle as well just not shown in pic. $175 (SOLD) 2. new set of plastic rear wheel weights. No decals on them not sure if oem wheel horse or not. $50.00 (pics coming) Share this post Link to post Share on other sites
HyperPete 886 #202 Posted May 23 2 minutes ago, stevebo said: Up for sale (delivered to the show) 1. 48” snow plow off a 418-8. Has the angle handle as well just not shown in pic. $175 2. new set of plastic rear wheel weights. No decals on them not sure if oem wheel horse or not. $50.00 (pics coming) I've been waiting for a plow to fit my 414-8 to present itself. I am completely unknowledgeable on plows. Does this need anything else to install & work? How does one raise & lower it. Thanks! Share this post Link to post Share on other sites
stevebo-(Moderator) 8,600 #203 Posted May 23 4 minutes ago, HyperPete said: I've been waiting for a plow to fit my 414-8 to present itself. I am completely unknowledgeable on plows. Does this need anything else to install & work? How does one raise & lower it. Thanks! You need the rear axle bracket only and that is all. They can be had at the big show easily. 1 Share this post Link to post Share on other sites
HyperPete 886 #204 Posted May 23 Just now, stevebo said: You need the rear axle bracket only and that is all. They can be had at the big show easily. Then I will take it. Thank you. I may ask for help identifying said bracket at the show if it's ok. 1 Share this post Link to post Share on other sites
adsm08 3,850 #205 Posted May 23 11 minutes ago, HyperPete said: How does one raise & lower it. There should be a solid lift link that attaches to the same rocker-shaft arm your deck's lift link attaches to. Then you use the existing implement lift mechanism. A piece of chain can be used, but I have found it can cause "float". Basically a flexible link can allow the plow to ride over denser spots, like where you may have already driven, while a solid link allows you to bring the whole weight of the tractor to bear on those spots. 1 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,600 #206 Posted May 23 1 minute ago, adsm08 said: There should be a solid lift link that attaches to the same rocker-shaft arm your deck's lift link attaches to. Then you use the existing implement lift mechanism. A piece of chain can be used, but I have found it can cause "float". Basically a flexible link can allow the plow to ride over denser spots, like where you may have already driven, while a solid link allows you to bring the whole weight of the tractor to bear on those spots. Plow has that lift link on it 1 Share this post Link to post Share on other sites
HyperPete 886 #207 Posted May 24 7 minutes ago, adsm08 said: There should be a solid lift link that attaches to the same rocker-shaft arm your deck's lift link attaches to. Then you use the existing implement lift mechanism. A piece of chain can be used, but I have found it can cause "float". Basically a flexible link can allow the plow to ride over denser spots, like where you may have already driven, while a solid link allows you to bring the whole weight of the tractor to bear on those spots. Thank you for the explanation. Now I can figure out the installation! 5 minutes ago, stevebo said: Plow has that lift link on it Perfect, thank you! Share this post Link to post Share on other sites
Ken B 3,202 #208 Posted May 24 Cast iron Toro weights. They weigh at least60:pounds each. Can deliver to the Big Show.. 200.00 takes them. 2 Share this post Link to post Share on other sites
adsm08 3,850 #209 Posted May 24 10 hours ago, HyperPete said: Now I can figure out the installation! Yeah, installing a plow is on par with putting a wheel on a German car for difficulty. Figuring out how everything goes together is easy, holding it there while you get the hardware put in is the hard part. 1 1 Share this post Link to post Share on other sites
S416-8 396 #210 Posted May 25 If interested I have 2 520's listed in the classifiids.. one I use often and the other I can be used for parts or restored.. pic of the running one is below 1 Share this post Link to post Share on other sites
WHX?? 53,289 #211 Posted May 25 On 3/26/2025 at 7:42 PM, WHX?? said: Wow and it wasn't even The Squonky ... Back on topic ... Three point hitch cat 0 2 inch receiver $65 SOLD @S416-8 On 3/26/2025 at 7:42 PM, WHX?? said: Share this post Link to post Share on other sites
Achto 30,170 #212 Posted May 25 11 hours ago, WHX?? said: SOLD @S416-8 Best tag that so you remember. 1 1 3 Share this post Link to post Share on other sites
Raposo 532 #213 Posted May 25 Looking for a long frame 12, 14, 16 horse. Running condition. If anyone has one they would sell message me! Like a c141, c120, c160 etc Share this post Link to post Share on other sites
Pullstart 68,519 #214 Posted May 25 5 hours ago, Raposo said: Looking for a long frame 12, 14, 16 horse. Running condition. If anyone has one they would sell message me! Like a c141, c120, c160 etc 8 speed or auto? Share this post Link to post Share on other sites
whtractors24 3,442 #215 Posted May 25 Looking for a real nice low back seat . Share this post Link to post Share on other sites
Bill D 2,441 #216 Posted May 25 10 hours ago, Raposo said: Looking for a long frame 12, 14, 16 horse. Running condition. If anyone has one they would sell message me! Like a c141, c120, c160 etc I have a 312-8 and GT 1800 for sale in the classifieds. PM me if interested. Share this post Link to post Share on other sites
sqrlgtr 1,290 #217 Posted May 26 Would like to find a 1257/67/76, actually any of the square hood or round hood gen/starter models . 1 Share this post Link to post Share on other sites
Ken B 3,202 #218 Posted May 26 (edited) Firestone tri rib tires in excellent shape on nice rims. Included is entire front axle out of my 418 including spindles. Great setup if you want to convert your small front tires machine to large tire. These tires are 200 a pair new. The tie rods are all new as well. 250 firm. Edited May 26 by Ken B 4 1 Share this post Link to post Share on other sites
WHX?? 53,289 #219 Posted May 26 4 hours ago, sqrlgtr said: Would like to find a 1257/67/76, actually any of the square hood or round hood gen/starter models . PM sent. Share this post Link to post Share on other sites
ljsdad414 123 #220 Posted May 26 (edited) C141 runs well, with rockshaft and sleeve hitch, no other attachments. Will come with turf ties on rear. Asking $400 $350. SOLD C175 runs well, no attachments, seat is in good condition. Asking $250 $200. 60 inch deck, SOLD Edited June 12 by ljsdad414 Price Change 2 1 Share this post Link to post Share on other sites
Docwheelhorse 2,792 #221 Posted May 26 @ljsdad414 I sent you a PM on 60" deck.... Let me know and thanks Tony 1 Share this post Link to post Share on other sites
Sparky-(Admin) 23,980 #222 Posted May 26 657 with a Magnum pullstart 8hp. Starts easy and runs great. No battery to maintain . Choke and throttle operate as they should and the factory ignition key is the kill switch for it. This was a project I did a few years ago to make it “similar” to a 1045 with the square hood and open rear fenders. Comes as you see it (wheels, tires stack-exhaust, rear hitch, seat etc) and will have a FULL TANK of ethanol free fuel so you can cruise around the show as much as you want. Perfect cruiser for the young-uns! $250 brought to the show. 3 5 Share this post Link to post Share on other sites
Pullstart 68,519 #223 Posted May 26 @Sparky I’ll take that 657 if nobody claimed it! 1 1 1 Share this post Link to post Share on other sites
Sparky-(Admin) 23,980 #224 Posted May 26 26 minutes ago, Pullstart said: @Sparky I’ll take that 657 if nobody claimed it! It’s yours! I knew if I wrote “pullstart” in the ad it would draw you in 7 Share this post Link to post Share on other sites
squonk 44,859 #225 Posted May 26 @Sparky He needs another tractor! I think I saw a clean spot in his shop in one of his video's! 6 Share this post Link to post Share on other sites
