Goldnboy 1,062 #1 Posted March 23 (edited) I see a lot of discussion about the handle index wire length but very little about the lower wire to the angle lock pin. I am currently doing a refreshing of a 42" blade and thought I would share these dimensions... Handle index 27 1/2" long 1/2" hook and 5/8" hook > part #104341 Lower index 18 3/4" long 5/8" hook and 1 3/8" " L" end > part # 3771 Sticky maybe? Edited March 23 by Goldnboy Added part #'s 4 3 Share this post Link to post Share on other sites
ebinmaine 74,588 #2 Posted March 23 Good info here! Share this post Link to post Share on other sites
Wayne0 1,357 #3 Posted March 23 Mine has a cable from the squeeze handle to the triangle pivot. Share this post Link to post Share on other sites
peter lena 9,460 #4 Posted March 23 @ Goldenboy , found every point of movement on the , steering quadrant , is vital , for detailing , eliminating play , and insuring lubricated swing movement areas , when you get it right , the quadrant swing pin , runs the entire , squeeze lever set up . also adding heim joints to the main push pull rods , makes a world of difference, add a lubricated finish to a plow , and it sheds snow like the plague . Share this post Link to post Share on other sites
Goldnboy 1,062 #5 Posted March 23 5 hours ago, peter lena said: @ Goldenboy , found every point of movement on the , steering quadrant , is vital , for detailing , eliminating play , and insuring lubricated swing movement areas , when you get it right , the quadrant swing pin , runs the entire , squeeze lever set up . also adding heim joints to the main push pull rods , makes a world of difference, add a lubricated finish to a plow , and it sheds snow like the plague . Thanks for the advice...however we are in dirt country...it will never see enough snow to push. 2 Share this post Link to post Share on other sites
