morning moon farms 4 #1 Posted March 17, 2025 Hello fellow tractor nerds, i have a C-100 series 8 speed that needs some help this spring. im looking for a 36" rear discharge mower deck belt and part #. and a drive belt 1 Share this post Link to post Share on other sites
Achto 31,135 #2 Posted March 17, 2025 Take a look through our free manuals. Should be able to find your tractor and the number for attachments that go with it. https://www.wheelhorseforum.com/files/ 1 Share this post Link to post Share on other sites
Blasterdad 3,163 #3 Posted March 17, 2025 Drive belt 102741 (1/2" x 96.6") for B-Series & C-Series tractors with 45-1/2" wheelbase (Gates replacement BladeRunner 6638BR 17/32" x 96.75") Spindle belt 8411 (1/2" x 76.94") 1 Share this post Link to post Share on other sites
morning moon farms 4 #7 Posted March 17, 2025 wow you guys are unreal. I appreciate the help and making me feel welcome in the wheel horse world . Jakoby 2 1 Share this post Link to post Share on other sites
peter lena 9,782 #8 Posted March 17, 2025 @morning moon farms WELCOME ! done a number of decks over , not that difficult , major issues are related to bearing noise / roughness / lubrication failure . typically all spindle bearings , as well as mule drive pulley bearing s , are the same 6203 3/4 2rsc3, with easily popped off grease shields , like a small fine putty knife or small flat pocket screwdriver , wipe out original lube , carb cleaner flush out , repack with LUCAS XTRA HD green chassis grease , polyurea rated and 550 deg flash point , imagine , no bearing whine or noise , just smooth easy engagement . that entire pto lever set up , can easily be changed into a very efficient , attachment . have also done related pto lever start , next to battery . cause and reason for related failure , is wrong original lubricant in those bearings , made for a ceiling fan , was never intended for heavy belt loading / drag , hi speed . good luck with it , pete 1 Share this post Link to post Share on other sites
ebinmaine 77,565 #9 Posted March 17, 2025 9 minutes ago, morning moon farms said: wow you guys are unreal. I appreciate the help and making me feel welcome in the wheel horse world . Jakoby Buncha decent folks around here. Whatever questions you have... fire away. 1 Share this post Link to post Share on other sites
rmaynard 16,910 #10 Posted March 17, 2025 According to the C-100 manual, your drive belt is: Transmission drive belt 78-7100 replaced by 7473 - 5/8" x 81.9" 2 Share this post Link to post Share on other sites
oliver2-44 11,272 #11 Posted March 18, 2025 The blue belts at Tractor Supply work well. 1 Share this post Link to post Share on other sites
