midpack 1,148 #1 Posted March 10, 2025 I have a 312-8 Classic with a locked transmission. My daughter's boyfriend was getting on it yesterday and accidentally hit one of the shift levers with his foot. Nothing moves and the drive belt just burns on the pulley. Wheels don't turn, shifters don't move... What kind of damage do you think might have happened? Share this post Link to post Share on other sites
ebinmaine 81,282 #2 Posted March 10, 2025 Sounds like it's locked between gears. See if you can get the shifter set screw out. 1 Share this post Link to post Share on other sites
953 nut 70,656 #3 Posted March 10, 2025 Take a look at this thread, it has what you need to know. Share this post Link to post Share on other sites
Pullstart 71,561 #5 Posted March 10, 2025 Keep us posted. I’ve never heard on this happening to anything but a 3 speed. Hopefully it’s not broken between hi and low. Share this post Link to post Share on other sites
WHX?? 58,388 #6 Posted March 10, 2025 (edited) 1 hour ago, Pullstart said: Hopefully it’s not broken between hi and low. Yep ... had that happen. Just tooling around on it and parked it. Hope fully did not happen to yours. Don't be too hard on the boy i caught my foot on levers many times. Yes pull the shifter and have a look see. Edited March 10, 2025 by WHX?? 1 Share this post Link to post Share on other sites
midpack 1,148 #7 Posted March 10, 2025 I got the shifter out and can see the forks are out of line. Tried to get them to move, rock the wheels, try to move the drive pulley. Nothing. Looks like I'll have to take it apart to see what's bound up. The guy (young man) who kicked the lever is a great person. Treats my daughter very well, I know he likes lawn stuff so I figured I'd let him give it a go. I'm not going to say anything about it, I like him 1 3 Share this post Link to post Share on other sites
stevasaurus 23,892 #8 Posted March 10, 2025 This may be of use...it;s the same as your trans except this is 1 1/8" axles with an 8 pinion differential. Yours should be 1" axles and a 4 pinion differential. 1 Share this post Link to post Share on other sites
WHX?? 58,388 #9 Posted March 10, 2025 43 minutes ago, midpack said: Nothing. Looks like I'll have to take it apart to see what's bound up. Yes best not try to force anything & make it worse. 2 Share this post Link to post Share on other sites
oliver2-44 11,847 #10 Posted March 10, 2025 Will the Hi/Los shifter move back and forth? Share this post Link to post Share on other sites
midpack 1,148 #11 Posted March 10, 2025 No, everything is stuck Share this post Link to post Share on other sites
c-series don 12,752 #12 Posted March 10, 2025 Not sure if it will help but did you try to rock the tractor back and forth while putting a little pressure on the shifters? Or are the wheels locked solid? 1 Share this post Link to post Share on other sites
adsm08 5,247 #13 Posted March 10, 2025 I'd jack the back end up to take all the tension off everything and try to get it back in line before going too in depth. I've seen many a 4x4 system "stuck" engaged and it was just tension from drive-line windup holding everything together. 1 Share this post Link to post Share on other sites
WHX?? 58,388 #14 Posted March 11, 2025 11 minutes ago, adsm08 said: try to get it back in line before going too in depth. Knowing the insides of these trannys like I do It the shifter would have to be wacked pretty hard to do any serious damage and even then. Weakest link is the fingers on the shifter forks tho. 1 Share this post Link to post Share on other sites
