peter lena 9,846 #1 Posted March 6, 2025 https://www.super-lube.com/super-lube-wire-rope-2 check out the temp functional range , local h/w stores or on line . liquid form , pete Share this post Link to post Share on other sites
Achto 31,527 #2 Posted March 6, 2025 In my experience Super-lube works well metal to metal or to coat electrical fillings with to keep corrosion at bay. It does not fair well with rubber or plastic coatings, seems to actually get sticky in those applications. With some cable sheathing having a plastic liner in it, I would be a bit leery of using it on cables. Prefer PJ1 cable lube myself. https://www.amazon.com/PJ1-1-12-Cable-Lube-Aerosol/dp/B00HRXOGVW/ref=asc_df_B00HRXOGVW?mcid=05443524fbbd37c093595c3749f1e3db&tag=hyprod-20&linkCode=df0&hvadid=693606727669&hvpos=&hvnetw=g&hvrand=2670779049480939346&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9021712&hvtargid=pla-571238522095&th=1 One of these works well to help force the lube into the cable casing. https://www.amazon.com/Motorcycle-Lubricator-Motorcycles-Bicycle-Scooter/dp/B0C8GBW271/ref=asc_df_B0C8GBW271?mcid=2ca30030b2ab3b22b9bc9410d872b6bf&tag=hyprod-20&linkCode=df0&hvadid=693338692942&hvpos=&hvnetw=g&hvrand=7788745433652530525&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9021712&hvtargid=pla-2281152264467&th=1 Share this post Link to post Share on other sites
peter lena 9,846 #3 Posted March 6, 2025 @Achto never had an issue with it , on any cabling , also have extension springs , on all my related cable linkage , smooth easy function , do what ever you like , pete Share this post Link to post Share on other sites
