Gilou15 53 #1 Posted March 3, 2025 Hello Here is the photo of my transmission number Someone can tell me more about it ... Axle shafts are 1"1/8 ..... Do you know the type of final pignon and diff.. What is the différence between it and 103916 eight speed ? Stronger or not ? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,557 #2 Posted March 3, 2025 That is the patent number that was on all the Uni-drive transmissions. From the information we have the 512-D had 1" axles using transmission model 110996. Click on the first picture. What we have with a 512-D search https://www.wheelhorseforum.com/search/?q=512-d&quick=1&type=downloads_file 1 Share this post Link to post Share on other sites
Gilou15 53 #3 Posted March 4, 2025 (edited) Bonjour! Merci pour les réponses et les documents ! J'ai donc annulé l'achat.! Car je préfère les transaxles plus costauds et je ne comprends pas pourquoi WH a fait ce choix pour un tracteur Diesel (cher) en 1986 alors qu'en 1979 il équipait une entrée de jeu comme le C101 des transaxles à huit pignons full size ? Je ne pouvais pas imaginer cela ; En outre : il est plus économique de fabriquer un seul type de transmission.... Vos avis !? Edited March 4, 2025 by Gilou15 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,557 #4 Posted March 4, 2025 Because I prefer stronger transaxles and I don't understand why WH made this choice for an (expensive) Diesel tractor in 1986 when in 1979 it equipped a starter like the C101 with full size eight-pinion transaxles? I couldn't imagine this; In addition: it is more economical to manufacture only one type of transmission.... Your opinions!? Share this post Link to post Share on other sites
lynnmor 9,081 #5 Posted March 4, 2025 The diesel had less horsepower than many gasoline engines. The reason for a diesel is fuel economy and in years past was cheaper by the gallon. There is no magic but many point at torque but that is taken care of by gearing if necessary. Share this post Link to post Share on other sites
Blasterdad 3,168 #6 Posted March 4, 2025 If your tractor has 1 1/8" axles you should have this 8 pinion transmission. Some models....(Toro lists this model as using the 110996 with 1" axle 4-pinion differential which is wrong) 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,557 #7 Posted March 5, 2025 (Toro lists this model as using the 110996 with 1" axle 4-pinion differential which is wrong) How did you determine this? Discovered one transmission page was missing from the ipl but found where Toro got the info for the manual. Have added the missing differential illustration between page 5 and 6 and deleted the first manual we had. Revised ipl 1 Share this post Link to post Share on other sites
Blasterdad 3,168 #8 Posted March 5, 2025 10 minutes ago, gwest_ca said: (Toro lists this model as using the 110996 with 1" axle 4-pinion differential which is wrong) How did you determine this? It's one of the footnotes in the file I uploaded, 1990 312-8 model 31-12K801 - Toro lists this model as using the 110996 with 1" axle 4-pinion differential which is wrong. I know that doesn't apply to the 512D, I was merely trying to assure @Gilou15 that he had a good transmission & not to worry. Share this post Link to post Share on other sites
Gilou15 53 #9 Posted March 5, 2025 I always can buy it if I am sure about the type of the transmission Can you show me the document where it is exactly specified the transmission for 512D ? Thanks Share this post Link to post Share on other sites
Gilou15 53 #10 Posted March 5, 2025 On the user Manuel the hubs are 1"1/8. The tractor I would buy is far and I cannot measure myself and the seller is unable to measure correctly !! What can I do to be sure ? Share this post Link to post Share on other sites
Blasterdad 3,168 #11 Posted March 5, 2025 Is there something wrong with your transmission? Share this post Link to post Share on other sites
Gilou15 53 #12 Posted March 5, 2025 No no problem but I would buy this tractor only if it is equipped with eight pinion diff , I only want this transaxle . I think if WH did it , there was a good reason !! Share this post Link to post Share on other sites
kpinnc 19,107 #13 Posted March 5, 2025 12 minutes ago, Gilou15 said: I think if WH did it , there was a good reason !! Not necessarily. Wheel Horse was notorious for clearing old parts inventory by introducing "special" model machines. In addition the 512D was an export model as well. Not surprising that the typical domestic rules weren't followed. Share this post Link to post Share on other sites
stevasaurus 23,892 #14 Posted March 5, 2025 This you can count on...if it has 1" axles, it IS a 4 pinion differential. If it has 1 1/8" axles, it has 8 pinions in this case. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,557 #15 Posted March 5, 2025 5 hours ago, Gilou15 said: I always can buy it if I am sure about the type of the transmission Can you show me the document where it is exactly specified the transmission for 512D ? Thanks Click on the fuzzy picture for the tractor details. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,557 #16 Posted March 6, 2025 Here are the models we know about 1986 512-D 8-Speed model B1-12R801 - Export model 512-De 1986 serial numbers that have shown up for the B1-12R801 20060 - Located in Onstwedde / The Netherlands 20106 1986 512-D 8-Speed model C1-12R801 - Export model 512-De 1987 512-D 8-Speed model B1-12R802 - Unknown model in Finland - Export model 512-De - Looks like a 1987 serial number. 1987 serial numbers that have shown up for the B1-12R802 010010 - Looks like a 1987 serial number. - Found in UK 010028 - Looks like a 1987 serial number - Found in Finland The 12 in the model number represents the approximate engine horse power Here is a chart explaining the model numbers. Click on the fuzzy picture to view the page. Share this post Link to post Share on other sites
Gilou15 53 #17 Posted March 6, 2025 (edited) Thanks very much for this explanatory table ! Very interesting to discover all manufacturing details... Edited March 6, 2025 by Gilou15 Share this post Link to post Share on other sites
