Mudrig150 399 #51 Posted July 30 Bit of an update: 1210 is gone. It's been sitting outside for 3 months and I ended up selling it, mainly because I needed money and I was never going to do anything with it. 4 tractors is already too many for what I do, and 5 is overkill. Diesel's been in a bit of a weird spot for a while now, I successfully did some dirt work with it and it handled it no problem, but while I was plowing the garden with it when it suddenly died like the engine locked up, then it wouldn't restart until it cooled off a bit. Hasn't done it since, but since that point, the starter's been acting up. It's doing what the old one did: it won't spin the starter gear unless you line up the flywheel by hand so that the gear can just go out and engage the teeth without rotating at all. Extremely annoying and makes me hate running it, really. Other than that I've just been cleaning it up. The 1912 has had the mower deck put on, but of course, it hates life. The column decided to start leaking power steering fluid everywhere which required a tear down and reseal, and of course it still leaks after being put back together. The main pressure line going into the column cracked after being forced back straight (all the lines got horrifically bent during shipping) so it leaks like a sieve now and will need replaced. Anyway, I got the deck on and decided to test it out, ran like crap as usual and then it decided to throw the driveshaft in the middle of the yard after about 20 feet, and then it threw the belt after fixing that. It's currently sitting because I have no idea where to go from here, the tractor still doesn't have a battery because there's literally nowhere to fit one and I don't want the battery to be mounted outside the tractor, and my plan of using it as a mower for the heavy brush got ruined because the deck only lifts 1/2" off the ground, it can't get the deck wheels off the ground even with them all the way up, despite the mule drive almost hitting the steering lines. I want to take the diesel to the steam show but it's not looking likely, both it and the 1912 are currently on backburner while I work on other things. Share this post Link to post Share on other sites
Mudrig150 399 #52 Posted August 2 Diesel's all cleaned, buffed and polished, at least on this one side. Other side's gonna be a nightmare to because everything blocks access... 1 Share this post Link to post Share on other sites
Mudrig150 399 #53 Posted August 23 Picked up a parts tractor for my 3000. Unfortunately the transmission on it is going out, but this guy has a good... uh... everything, except the engine. Mine's about the opposite unfortunately. Share this post Link to post Share on other sites
Mudrig150 399 #54 Posted September 5 Cleaned up the fuel system on the 3000 to get it ready to rake hay and WOW, it was bad. Got filters changed and flushed all the junk out of the fuel system. Turns out all my rust was coming from the filters themselves, not the tank. Unfortunately, even after all that work, the hay got raked by the big tractor, so I decided to get the parts tractor split. Actually wasn't as hard as I thought. Next step is splitting the diesel and swapping the flywheels and ring gears. 1 Share this post Link to post Share on other sites
Mudrig150 399 #55 Posted September 10 Engine's on... never want to do that again. My engine hoist got damaged so I had to use a bottle jack to hold the back of the pan up. Wasn't a fan of that sketchy setup and apparently those fears weren't unfounded: Somehow the jack caught on something and flipped forward, which caused the engine to tip over, landing with the radiator almost touching the fuel tank at like a 115° angle. Luckily the only damage was to the battery tray since the engine kind of rolled sideways instead of straight backwards, and because it rolled it didn't do any major damage to the clutch except scratching it up. Getting the engine on wasn't fun since the fall knocked the clutch discs out of alignment so it took a lot of finesse to get the splines in. It's all on though, and that part is done. Just need to get the fuel system put back together, electrical hooked up, and the front axle swapped and it should be done. 1 Share this post Link to post Share on other sites
Mudrig150 399 #56 Posted October 21 Been slowly chipping away at this project. So far, I've had a few major issues to fix, biggest one being the clutch. Clutch was dragging really bad, but was still somewhat releasing. Turns out I missed the splines with the PTO clutch disc and accidentally ripped the hub out of the disc, requiring the whole tractor to split and the clutch disassembled. Second picture is the torn out hub from the old clutch disc. New clutch is in and I actually made sure to look into the bell housing to align the clutch splines properly. Also discovered some weird adjustment issues that would've definitely caused clutch problems. This entire second tear down wasn't as involved as the first one but the amount of stuff I did was far higher: I put on a "new" battery tray, got a drawbar, resealed the steering column, swapped a bunch of parts over... This has been a process. Working toward getting it all together before I mount the cab to it, tried starting it today after reassembly and of course it won't start... 1 Share this post Link to post Share on other sites
sjoemie himself 3,238 #57 Posted October 21 Despite the struggles looks like you're making headway. Be sure to be safe out there though! Parts damaged is no fun but breaking bones or losing a limb is far worse. P.s. is that a Massey cab you're fitting to the Ford? Share this post Link to post Share on other sites
Mudrig150 399 #58 Posted October 22 7 hours ago, sjoemie himself said: Despite the struggles looks like you're making headway. Be sure to be safe out there though! Parts damaged is no fun but breaking bones or losing a limb is far worse. P.s. is that a Massey cab you're fitting to the Ford? IH 66 series. It's a really close fit and has more headroom than the aftermarket cozy cabs do. 2 Share this post Link to post Share on other sites
Mudrig150 399 #59 Posted 3 hours ago Got the cab at least sitting on the machine. Injection pump is still weeping fuel from the bleed off line on the top cover, though, to be fair, the crush washers have been removed and retightened like 4 times now. I have a plan for brackets, the pedal modifications, and the floor brackets. It's all going to be tight in terms of fit but I think it'll all work out. Share this post Link to post Share on other sites
