ebinmaine 76,508 #26 Posted October 5, 2025 21 minutes ago, Mudrig150 said: engine in it is way heavier than you'd think That may the issue.... See if there's a way to adjust tire tow in/out. Be sure they're towed in a little. Share this post Link to post Share on other sites
Mudrig150 375 #27 Posted October 5, 2025 8 minutes ago, ebinmaine said: That may the issue.... See if there's a way to adjust tire tow in/out. Be sure they're towed in a little. The toe is set properly. The diesel cubs have issues with steering being heavy, it's not uncommon for the steering boxes to start ripping apart from the added stress. The original steering box was actually pulling the bolts out of it when turning to the right. 1 Share this post Link to post Share on other sites
Mudrig150 375 #28 Posted October 5, 2025 Throttle and choke cables installed, side panels cleaned up, headlights are in... Looking a lot better than the shabby frame I got it as! 3 Share this post Link to post Share on other sites
Mudrig150 375 #29 Posted October 9, 2025 Test fit of the cast rear after a thorough cleaning, inspection, and internal swap. Housing came from my old 1250 transmission, I pulled it from the tractor when I did a ported pump swap (swapped the entire transmission from a 1650 in), then dumped it in the scrap pile. Never would've thought that 5+ years later I'd be using it for something. The pump was totally trashed, rusted solid from sitting with no freewheel valves in it, but the rest was surprisingly fine despite the obvious water line showing that it had like 6" of rain water in it at some point. Guts all got swapped and I am frankly surprised how smooth it went, despite it being a garden tractor transmission casting. Usually people use a 982 transmission casting from what I've seen. Afterward, I went searching for patina'd bolts and ended up finding all but 2 that I need: of the 7 rear cover bolts I found, 2 are slightly too long. Had to use a bottle jack to shove the frame rails back apart after the previous owner bent them lifting the tractor frame and the 250+ lb deck up by the unsupported back end. Rims got cleaned up nicely since they were coated with greasy dirt from the relief valves leaking. Once gaskets and seals arrive I can finalize assembly and measure my driveshaft length. 2 Share this post Link to post Share on other sites
Mudrig150 375 #30 Posted October 11, 2025 Finally got my tank mounted, and the fender support brackets drilled. I don't think a rear 3 point will work on this tractor with the fuel tank that's in it, unfortunately. I think the rockshaft is going to hit the bottom of the tank. Planning on getting my driveshaft adapter from Jeff in PA so I can get the length measurement for the driveshaft shortening. Slowly getting closer and closer to getting it all done... 2 Share this post Link to post Share on other sites
Mudrig150 375 #31 Posted October 18, 2025 Well I've spent the last 2 days running the 1912 trying to get it dialed in and I've found three problems: 1. It idles like crap. It really struggles. It doesn't even out with choke and runs like it's flooding but there isn't an adjustment for the idle mixture so that's a problem I straight up can't fix. 2. It blows oil smoke on and off. It doesn't do it constantly, but it definitely does do it. 3. It has a horrendous bottom end knock. It sounds like a rod is about to punch through the side of the block at any second, and it's definitely not valve related. I think it's kaput, which is a shame because I haven't even driven either of the tractors that the engine has been mounted in. I'm gonna see if I can gain access to the inside of the engine to see exactly what's going on but I don't think it's going to be good. 1 2 Share this post Link to post Share on other sites
Mudrig150 375 #32 Posted October 24, 2025 1912 had its first drive today! Made a few minor errors while putting it together including forgetting the suction tube and the expansion plug for the front of the transmission, thought the transmission was blown up because I forgot to tighten the hydro filter, but it runs and drives! Still need a steering box to fix the backwards steering, the pressure line to the hydraulic valve, axle seals, a harness, and a choke cable, and a bunch more small parts. Electrical is going to be a whole thing but honestly there's been worse parts to this project so far. 1 1 Share this post Link to post Share on other sites
ebinmaine 76,508 #33 Posted October 24, 2025 Niiiiice Share this post Link to post Share on other sites
Mudrig150 375 #34 Posted October 28, 2025 (edited) Just working on cleaning her up a bit and getting a harness made. Seat's looking good on there! It's so funny parking it next to the 655 because the 655 feels like a huge tractor but the 1912 is only a few inches shorter in terms of height and width, not counting attachments. Wheelbase is exactly the same, hilariously. Edited October 28, 2025 by Mudrig150 2 Share this post Link to post Share on other sites
Mudrig150 375 #35 Posted November 16, 2025 Batch of parts for the diesel. They look awful but should clean up well. Good grille casting with a good IH emblem and headlights, seat and brackets, fender pan with taillights, and a dash for parts. 3 Share this post Link to post Share on other sites
Mudrig150 375 #36 Posted November 18, 2025 Diesel is slowly going back together. Eventually I'll have to pull it to the front and pull the engine to replace the starter and some annoying to reach gaskets. Going to be doing some fab work, taking a firewall from a parts tractor and modifying it to go in front of the battery to do three things: keep the battery from walking off the tray due to the front being cut off, give some support to the hood to prevent it from breaking the top of the dash again, and also to keep the battery from shorting against the hood if the hood breaks the dash again. Shame the hood (not pictured) is so bad looking, they seem to have sanded all the red off and then shoddily painted it white. I don't have the kind of money that people want for an original diesel hood, nor do I really think that it's a huge priority thing to buy given the leaking injectors and the completely gutted and rotten muffler... 4 Share this post Link to post Share on other sites
Mudrig150 375 #37 Posted December 9, 2025 After 6 years, the search for the Burns engine is over! As far as I know it's the correct spec for the tractor, little bit newer than it but it's a 6 hp with the old style flywheel shroud which was really what I was looking for. Air cleaner is completely disintegrating and the pull start is gummy but it has compression so I'm hopeful. Excited to get it running to finally get this tractor going again! 1 1 1 Share this post Link to post Share on other sites
ebinmaine 76,508 #38 Posted December 9, 2025 Niiiiice 1 Share this post Link to post Share on other sites
Mudrig150 375 #39 Posted December 19, 2025 Had all three 82 series out today to swap them around a bit. Diesel is running and starting great following a minor overhaul (firewall to support hood, glow plug relay, new starter, repaired wiring to the starter solenoid) Found a very "professional" implementation of a brake switch bypass that was making the starting circuit totally non-functional (starter would click but wouldn't actually spin). I banished the 1210 to the back given its current non-running state with the completely worn out K301 so the diesel, that actually starts off the battery now, can be at the front of the shed. Also got the diesel cleaned up a bit. Still a few more things to fix on it, but it's a massive improvement to what it was when I got it. Share this post Link to post Share on other sites
Mudrig150 375 #40 Posted December 21, 2025 Nevermind on the Burns, I guess. New engine is trashed as well. No compression at all after lapping, cleaning, and adjusting the valves. Guess I'll be looking for engine number 8... Share this post Link to post Share on other sites
Mudrig150 375 #41 Posted December 23, 2025 Had the diesel out moving a bit of scrap. Ground's super wet so it spent half the time spinning the tires but I made it with ample use of the turning brakes. This tractor runs better and better every time I run it, the blowby is completely gone and so is the surge at idle. 1 Share this post Link to post Share on other sites
