Mudrig150 405 #1 Posted February 27, 2025 I've been gone 5 years? Feels like a lot less, frankly. I don't even know where to start with how to catch up. So... the fleet has definitely changed since I last posted, half of it's gone, and replaced with new tractors. I sold my 317, I still have my Burns, 140, and 110, and in the last year I bought three cub cadets: a 1210, a 782, and a 782D. I'll give a brief summary of what I've done to each: Burns Basically nothing. I got it running, then the drive belt jumped, seized the whole driveline, and then killed the engine by somehow throwing off the timing without shearing the flywheel key. 140 I originally had it running, and replaced the axle seal, but it kept leaking. Turns out, the entire axle housing was bent, meaning that it would never seal. I found a used housing and got it all back together, ran it for a bit, and it's currently parked because the engine is super tired and super down on power, and I accidentally broke the lever linkage for the outside handle. 110 I've done a good bit with tractor: added headlights, swapped tires, put the plow on, cleaned it up a bit... It needs paint bad. Currently in storage. 1210 Bought it a few months ago for $225, it's an early one with the K301 instead of the M12, managed to get it running, and have gotten it cleaned up and looking so good for an all original tractor. Hydraulic lift is half installed but I still need to figure out how to get the 3/8" roll pins out to remove the rockshaft and swap the hydraulic lift rockshaft in. I've mowed with it several times, heck, it's actually the first tractor I've ever had that can actually mow grass, and it does a dang good job of it. 3 1 Share this post Link to post Share on other sites
Mudrig150 405 #2 Posted February 27, 2025 782 Bought it as a parts tractor for the 1210 for $50, but ended up changing my mind on the whole "parts tractor" part. Originally had a series 1 that lost compression (two guesses as to what happened around here in hill country), then got swapped to a series 2, that was then itself removed and thrown onto a log splitter. Not a looker by any stretch of imagination but it's still pretty nice, so I decided to repower it. Instead of a command or a vanguard, with me choosing to be stubborn and different, I decided to pick up a Kawasaki FD620D from a Cub cadet 3205 to replace the missing engine. It's currently about 1/4 of the way through the swap, the engine is in the frame but it needs a driveshaft, fuel system, and wiring. 782D Oh, where do I begin... I bought it as one of my bucket list tractors for $500, sold as a non-running tractor, potentially with a bad engine. Previous owner said that it wasn't getting fuel out of the injectors, and he was definitely right in that regard. The engine had 0 injection pressure, and was only dribbling out the tiniest amount of fuel, not even trying to run. I had to dig way into the engine to find that the injection pump plungers had been put in backwards by the original owner, blocking fuel flow to the injectors entirely, but even after doing that, it still wouldn't start... Until it suddenly just fired up after multiple days of trying. Runs great now after removing the tank strainer that was getting sucked into the fuel line and blocking it, and I've been working on it lately, putting a 3 point and dual brakes on it. I plan on gardening with it this summer. The 782D is currently rocking the hood and grille off the 782 for now, since its hood and grille are in a sad state. That's about it. I have been hard at work on other projects like getting our 3020 going again, got it running last year after sitting for 12 years, so that's about all I can say about the garden tractors. 5 1 Share this post Link to post Share on other sites
T-Mo-(Moderator) 5,005 #3 Posted February 27, 2025 Hey, Mud. I remember you from both this site and WFM. Yeah it's been awhile since you been on here and WFM. Nice collection of small tractors. 1 Share this post Link to post Share on other sites
ebinmaine 81,281 #4 Posted February 27, 2025 Welcome back! I've always liked those IHC x82 series. My maternal Grampa had one. Share this post Link to post Share on other sites
Achto 32,963 #5 Posted February 27, 2025 Welcome back. Any chance you can show a picture of the ID tags on those x82 series? Just curious if they are IH or MTD built. IH built will say International Harvester made in Chicago IL on it. MTD built will say Cub Cadet made in Louisville KY or Cleveland Ohio. 2 Share this post Link to post Share on other sites
Mudrig150 405 #6 Posted February 28, 2025 13 hours ago, Achto said: Welcome back. Any chance you can show a picture of the ID tags on those x82 series? Just curious if they are IH or MTD built. IH built will say International Harvester made in Chicago IL on it. MTD built will say Cub Cadet made in Louisville KY or Cleveland Ohio. The 782 is the only IH built one, the other two are MTD built. The 782 actually has international harvester on the tag while the other two are just Cub Cadet. 1 1 Share this post Link to post Share on other sites
Mudrig150 405 #7 Posted March 4, 2025 Another machine I've been working on. Apparently putting this specific axle on this tractor is the most controversial thing I could be doing because it has caused so many arguments... 1 Share this post Link to post Share on other sites
Mudrig150 405 #8 Posted March 18, 2025 After much work, I now have a working PTO and starter on the diesel. Starter didn't work due to corrosion, and the PTO had its power wire hooked to ground instead of to the key switch, so the whole circuit was grounded on both ends. Unfortunately it won't be plowing our garden but I do get to disk it and then plant it. Really need to find a seat for it somewhere. 1 Share this post Link to post Share on other sites
Mudrig150 405 #9 Posted June 14, 2025 Lot of work done lately. Bought a 216 for the engine for my 140, got the 1210 running again and mowed with it. Fixed the hydraulic handles on the 140, pulled the steering wheel off the 216 to replace the horribly faded and deteriorating one, cut up the melted headlight panel and the broken headlight panel to combine into one nice one, found a nicer hood, and tightened up the steering on the 140. Kinda feel sad that Larry has lost his most prominent feature, but unfortunately, the old headlight panel had some serious cracks and was barely holding together, and would've broken eventually. Just need to get the engine out of the 216, fix the compression leaks, and put it in the 140 to replace the gutless K241. 1 Share this post Link to post Share on other sites
Mudrig150 405 #10 Posted June 17, 2025 Frame cleaned on the 782 and engine is finally bolted down. Driveshaft shortening is going to require a shop because I am not entirely confident in my skills enough to cut and weld it myself. 1 Share this post Link to post Share on other sites
ebinmaine 81,281 #11 Posted June 17, 2025 2 hours ago, Mudrig150 said: Driveshaft shortening is going to require a shop because I am not entirely confident in my skills enough to cut and weld it myself My understanding is that the balancing is a specialist job. Looks good! 1 Share this post Link to post Share on other sites
Mudrig150 405 #12 Posted July 13, 2025 This tractor confuses me so much. Was running great, then started running horrendously, then started blowing smoke like a freight train, then it runs fine again. I think an injector is failing (not surprising given the high hours and complete lack of a fuel system service, ever), but I'm not entirely sure what that's about. Anyway, my hand was slightly forced in terms of swapping the front tires, but I got a set of 10.00x16s thrown on that I found. Rear tires still need swapped and the axle plate needs trimmed to clear the tie rods but it's coming together nicely. Thinking 7.50-16 or 9.00-16s would be more appropriately sized, but I'm using what I got. 2 Share this post Link to post Share on other sites
Mudrig150 405 #13 Posted August 16, 2025 3020 got the canopy put on, I raked with it, and then I dug the weights out of storage and put them on. Tires on the silver rims were completely disintegrating so I ended up taking the tires off the rotten rims and swapping them onto some nicer (and actually yellow) rims. Larry and the 1210 got all cleaned up and went to the steam show, I pushed dirt with Larry and it was actually a ton of fun, and putting the 16 horse through its paces was nice. Also got my brother's 140 running for the first time in 7 years and took it to the show as well. 2 Share this post Link to post Share on other sites
Mudrig150 405 #14 Posted August 16, 2025 Also picked up a nice little piece of kit for the 140s. Only fitting given the fact we have 4 of them, including one patio. Was a good deal so just had to have it. 2 1 Share this post Link to post Share on other sites
Mudrig150 405 #15 Posted August 29, 2025 Someone needs to take marketplace away from me... The original Onan was super blown up so I left it behind. Wasn't even supposed to come with a rear axle but I ended up asking if I could take the bad transmission from the 2072 that was given this 1912's transmission. Thinking of either swapping the 782's engine into this and the 782D's engine into the 782, or swapping the 782D's engine into this tractor. Either way, the 782D will be giving up its transmission for this sad girl. 2 Share this post Link to post Share on other sites
Mudrig150 405 #16 Posted August 30, 2025 Transmission is back in and gave it a bath. On the hunt now for a fender pan and some other missing parts... 2 Share this post Link to post Share on other sites
Mudrig150 405 #17 Posted September 3, 2025 1912 is safe and sound inside. Engine mount plate is off, of course the bolts had previously run loose and were smashing into the axle, 2 nice witness marks where the bolt heads hit... Need to do some cleaning in the frame and then the Kawasaki can be dropped in. Steering box is going to need replaced but I think that a square fender Deere box will bolt right up, though I'll need to confirm if the length is right. Hopefully everything else goes smoothly enough... 1 Share this post Link to post Share on other sites
Mudrig150 405 #18 Posted September 10, 2025 Engine is in, doing a bit of cleaning. Got some of the rust off the hood and scraped as much of the dirt out of the inside as possible. Also got the tunnel cover straightened out enough for the holes to line up. I got some square stock ordered to space the tank and fenders higher up and get everything bolted down. I know the picture sucks, but does it look like I have enough room to fit a rear PTO? I would love to have one but not sure it'll fit if it sticks up above the frame rails to the point of interfering with the fuel tank. The bottom of the tank will be pretty much level with the top of the frame. 3 Share this post Link to post Share on other sites
ebinmaine 81,281 #19 Posted September 10, 2025 2 hours ago, Mudrig150 said: does it look like I have enough room to fit a rear PTO? I would love to have one but not sure it'll fit if it sticks up above the frame rails to the point of interfering with the fuel tank I've never messed with a Cub so I can't answer for certain. @WHX?? or @Achto might know. 🤔 I'd say experiment with proper spacing and leave plenty of room for error. 1 Share this post Link to post Share on other sites
Achto 32,963 #20 Posted September 10, 2025 It looks like every thing mounts behind the rear diff cover. The rear mounted gas tank looks like it may cause some issue towards the top. But when there's a will there's a way. Some pics of the factory rear PTO. Share this post Link to post Share on other sites
Mudrig150 405 #21 Posted September 11, 2025 Yeah, I definitely won't be able to run the PTO. Tank interferes with the rockshaft for the 3 point arms. Oh well. Share this post Link to post Share on other sites
Mudrig150 405 #22 Posted September 11, 2025 Got the engine in and the steering back together on the 1912. Made a huge error when ordering a column, and bought one for a Deere just worried about length. Put the column in, turned steering wheel to the left... wheels turned right. Turns out the worm on the 1912 box is flipped compared to every other steering box I have. It's good enough to mock everything up, I suppose... I'm now down the 1912/982 specific column AND missing the 1912/982 specific hydraulic line to the valve. Seems like every 1912 specific part is either busted or missing... Share this post Link to post Share on other sites
Mudrig150 405 #23 Posted October 5, 2025 Finally got an exhaust for the 1912. There isn't an off the shelf muffler that fits, so I figured the most common one would be my best bet. Pump needs torn down for an internal inspection to see why it stopped driving but the missing trunion springs and the trailer ball on the back kind of give me an idea. Still need to get the driveshaft figured out which is definitely going to cost me because none of the factory driveshaft options fit, either because they hit the radiator (in the case of the rag joint driveshaft) or are too long (in the case of the 2000 series or cyclops CV driveshaft) I've got to find a shop to cut and weld the 2000 series driveshaft shorter so it'll fit. I've got a list of parts left to make or buy: driveshaft fan and pump coupler, pressure line to the hydraulic valve (982/1912 specific, of course), steering box, wiring, battery box, muffler heat shield, a brake caliper, plus the throttle and choke cables since the factory ones are too short. Hoping to get the 1912 going to run the snowblower this winter because the 20 hp is going to be nice for that. The diesel is also being torn down, I want to get power steering from a super because its steering is weirdly heavy, and also to replace the starter since it decided to up and die on me. 2 Share this post Link to post Share on other sites
ebinmaine 81,281 #24 Posted October 5, 2025 6 hours ago, Mudrig150 said: because its steering is weirdly heavy Have you tried replacing parts to narrow the issue yet? I've had several Horses as you know. Some have different personalities. Sometimes you can swap a part or adjust the tie rods and make a difference... Share this post Link to post Share on other sites
Mudrig150 405 #25 Posted October 5, 2025 1 hour ago, ebinmaine said: Have you tried replacing parts to narrow the issue yet? I've had several Horses as you know. Some have different personalities. Sometimes you can swap a part or adjust the tie rods and make a difference... I have not. I'm not even sure where to start. The tires are aired up, the tie rods move freely, the spindles are well greased, but it's a bear to turn. That engine in it is way heavier than you'd think so it's definitely not helping. Share this post Link to post Share on other sites
