HyperPete 910 #1 Posted February 26, 2025 (edited) Well, I decided to jump into the 414-8 shown below. Asking price was 500. Purchase price was 300. - All 4 tires are pretty badly cracked. I have a set of Carlisle rear tires in the correct size off my '73. - Mower height adjuster is broken off at the (HORRIBLE) factory weld. A very simple fix. - Gas cap needs to be replaced. - Knob to front mule is broken. - Knobs for shift levers are AWOL. - Trans oil is milky, needs drain, flush, refill. - Slightly "notchy" shifting into 3rd, both high & low range. I am hoping the drain/flush//refill and linkage adjustment will fix t. If not, an 8-speed arrives tomorrow. - Transmission "boot" for gear selector lever is shot - Left outer deck spindle bearing squeaks when PTO is engaged. No grease on the zerk fitting, hoping grease fixes it. - SLIGHTLY worn right (inner) tie rod end. - SLIGHT front wheel bearing play. - Seat is all torn up and taped - Gas strut on seat completely worn out - Edge of hood by dash is damaged/bent - Lots of paint falling & chipping. A bit of surface rust. - I'm sure it's the wrong battery, but it's brand new. Cheapo lawn tractor battery. Struggles to start it. - Battery hold down loose, likely because of wrong battery. - Engine runs great! Does not idle extremely low. I'll disassemble and clean the carb. - Needs an oil change. So, ok deal? Edited February 26, 2025 by Pete D 5 8 Share this post Link to post Share on other sites
JCM 10,855 #2 Posted February 26, 2025 Magnum engines are tough and reliable.Eight speeds are solid. Good luck with it. 2 1 Share this post Link to post Share on other sites
Skwerl58 801 #3 Posted February 26, 2025 I love my 414-8. You just have a regular maintenance list to complete and that 14hp magnum has plenty of spunk. Remember to lift the front of the tractor to drain the trans lube. Replace the fuel lines and add a good filter also. Change the spark plug. The carbs will wear at the shaft and will cause some issues but most can be repaired with bushings. Lots of help will come along. Enjoy your tractor, it should last for quite a few more years. 2 Share this post Link to post Share on other sites
pfrederi 19,996 #4 Posted February 26, 2025 I think you got a winner 2 Share this post Link to post Share on other sites
OutdoorEnvy 1,807 #5 Posted February 26, 2025 That’s a good grab for sure! It’ll provide some project entertainment and then you’ll have a great reliable rig for quite some time. Hard to be an eight speed with single cylinder Kohler in my book. 3 Share this post Link to post Share on other sites
WHX?? 55,452 #6 Posted February 26, 2025 (edited) Not a bad deal and a very good foundation for a fixer upper. Found it this time EB Edited February 26, 2025 by WHX?? 1 2 Share this post Link to post Share on other sites
kpinnc 17,405 #7 Posted February 26, 2025 14 horse Magnum tied to an 8-speed? That's an awesome combination! Yes, that's a good choice! 2 Share this post Link to post Share on other sites
grinchsr 657 #9 Posted February 26, 2025 I would have paid $300 even without the deck. 2 Share this post Link to post Share on other sites
rjg854 12,875 #10 Posted February 26, 2025 Sounds like a good deal, even with having to invest in it. And like has been said a good tractor overall. I've seen people trying to sell 's not running for $300. 2 Share this post Link to post Share on other sites
HyperPete 910 #11 Posted February 26, 2025 My only real concern is the deck height adjuster. I just need to find a closeup photo to ensure everything is there, and so i can position it properly. I'm not planning to use the mower on it anyway so that's inconsequential. I have a battery tray and hold down for $4.82 arriving tomorrow, that should take care of the battery hold-down issue. The specs say it takes a U1 battery, so maybe it is the correct battery for it after all. I'll confirm the rated CCA when I take it off my truck. If that's the case, and it just doesn't need to be charged, I may have to disassemble the starter and clean it. I kind of doubt that will be the case though; he said it was 3 weeks old and he hasn't run it much since he purchased the battery, so I think trickle charging it should take care of any issues. I'll be assessing it further today. 1 Share this post Link to post Share on other sites
Blasterdad 3,163 #12 Posted February 26, 2025 (edited) 41 minutes ago, Pete D said: My only real concern is the deck height adjuster. I just need to find a closeup photo to ensure everything is there, and so i can position it properly. From you FB pic this looks like it should be your deck... Click on fuzzy pic or download for all files... Edited February 26, 2025 by Blasterdad 1 1 Share this post Link to post Share on other sites
HyperPete 910 #13 Posted February 26, 2025 @Blasterdad - Thank you! I'm wondering if there are any parts missing. It's actually 2 welds, and I think I'll be patching the deck there and in some other spots at the same time. I think I with strip, wire brush or sandblast the whole deck, fill and level where needed, and repaint it. Then put it in storage. 🤓 1st photo is deck label 2nd photo is without the loose parts 3rd is with the 2 parts I have, just loosely sitting (generally) in place. 1 Share this post Link to post Share on other sites
HyperPete 910 #14 Posted February 26, 2025 (edited) More pictures I took today. Model/serial# (1) 4 1/2" headlight burned out. I will look for LED replacements. EDIT: $41 LED replacements on Amazon Damage to hood sheet metal. I can get it into rough shape. Not interested in perfection. Champion spark plug, to be replaced with NGK Rubber anti-slip pads to be placed, possibly with "sandpaper" type. Wire nuts? Really?! Wiring to be done properly. Also, looks like aftermarket relay, but it works. 300 CCA U series battery (UP1). Still a flat spot starting. Not a major issue, but I suspect the starter is bad, internally. Seat "bushings"/stops deteriorated. To be replaced along with damper rod. June show? Bad gas gap, and seat switch disconnected/missing, causing dash light. To be replaced. June show? Missing gear selector knobs. To be replaced. eBay, or June show. Broken reflector. Auto parts store or eBay if I can get a part#. Lots of mower deck rust, plus good underside. Clean rust, assess, fill & level, paint, store. Edited February 26, 2025 by Pete D Add LED headlights info 1 Share this post Link to post Share on other sites
kpinnc 17,405 #15 Posted February 26, 2025 (edited) You still did well. Every tractor I have started that bad or far worse. Sadly the durability of these machines translated to some people thinking that they could be left out in the rain and improperly maintained. Everything you show "wrong" is completely fixable. I look forward to you getting her back in service! Edited February 26, 2025 by kpinnc 1 1 Share this post Link to post Share on other sites
HyperPete 910 #16 Posted February 26, 2025 1 minute ago, kpinnc said: You still did well. Every tractor I have started that bad or far worse. Sadly the durability of these machines translated to some people that they could be left out in the rain and improperly maintained. Everything you show "wrong" is completely fixable. I look forward to you getting her back in service! Yes, the deck is the worst of it. No pics of the torn boot on the transmission, and the milky oil is not very bad. It might just be from condensation, but I'll still flush it before replacing the oil. I also forgot the taped up seat. I will use it as-is and see what's available at the big show. If nothing, I'll either get a cover, or see what an upholstery shop will charge me to redo it (after painting the pan). 2 Share this post Link to post Share on other sites
Blasterdad 3,163 #17 Posted February 26, 2025 Here is the correct manual for your deck, pretty much the same, in your second pic of the deck the selector arm is upside down & the spring is missing. Is the selector quadrant what you're refering to as needing to be welded? 1 1 Share this post Link to post Share on other sites
HyperPete 910 #18 Posted February 26, 2025 (edited) 12 minutes ago, Blasterdad said: Here is the correct manual for your deck, pretty much the same, in your second pic of the deck the selector arm is upside down & the spring is missing. Is the selector quadrant what you're referring to as needing to be welded? Yes, I believe it's the selector quadrant. The part I circled, bottom right. I also see my LH & RH belt covers are missing. And the rubber flap at the back of the deck. After I get it clean, welded, patched, & painted, I'll try to find them. Edited February 26, 2025 by Pete D Add photo 1 Share this post Link to post Share on other sites
Blasterdad 3,163 #19 Posted February 26, 2025 3 minutes ago, Pete D said: I also see the LH & RH belt covers are missing. After I get it clean, welded, patched, & painted, I'll try to find them I leave all mine off, easier to clean out the pulleys & slides after EVERY time I mow. I have a set if you can't find them. 1 1 Share this post Link to post Share on other sites
Blasterdad 3,163 #20 Posted February 26, 2025 9 minutes ago, Pete D said: Yes, I believe it's the selector quadrant. The quadrant is not welded to the deck, it bolts on under the axle bracket like the pic shows. 2 Share this post Link to post Share on other sites
Blasterdad 3,163 #21 Posted February 26, 2025 Here's one of the manuals for your tractor... 1 1 Share this post Link to post Share on other sites
HyperPete 910 #22 Posted February 26, 2025 (edited) The tires I have are 10.5 wide. They are off my '73 which calls for 9.5" wide tires. The 414-8 calls for 8.5" wide tires. With the 10.5s fit? It looks like there is plenty of room. Edited February 26, 2025 by Pete D 1 Share this post Link to post Share on other sites
Handy Don 16,048 #23 Posted February 26, 2025 (edited) 33 minutes ago, Pete D said: The tires I have are 10.5 wide. They are off my '73 which calls for 9.5" wide tires. The 414-8 calls for 8.5" wide tires. With the 10.5s fit? It looks like there is plenty of room. Yes. They will widen the rear track, bringing the rear wheels closer to the edge of the mown swath of the 42” RD deck. Edited February 26, 2025 by Handy Don 1 1 Share this post Link to post Share on other sites
HyperPete 910 #24 Posted February 26, 2025 13 minutes ago, Handy Don said: Yes. They will widen the rear track, bringing the rear wheels closer to the edge of the mown swath of the 42” RD deck. Awesome! That's a non-issue for me, tilling & pushing snow. 1 Share this post Link to post Share on other sites
oldlineman 1,656 #25 Posted February 27, 2025 Great tractor, I have 1989 414-8, with a nos 48 deck I purchased about 5 years ago near Gettysburg Pa. at a Toro dealer. Clean it up and it will serve you well. 3 Share this post Link to post Share on other sites
