Greentored 3,221 #1 Posted February 18, 2025 Hope you all are doing well! Ol Hoss the custom pooped a gen, I think? Whirls the built, 9.3:1 K321 over like nothing, but 0v coming out of the arm terminal. New battery and correct regulator, grounds are all clean, wiring checks out fine (only a few years old). Took it apart and nothing jumps out at me except its a little dirty- even the brushes and springs look great. Arm and field continuity tests passed. While I dont have a TON of experience with starter/gens, my old Harley has had its share of gen issues over the years, and I always tested it by 'motoring' it- if it motored, all was functioning and it would charge. Im stumped here fellas, any ideas? Share this post Link to post Share on other sites
ebinmaine 80,741 #2 Posted February 18, 2025 Hiya Scott! There are bench test instructions for old tractors on youtube. Do not use bench test instructions for a car because they don't use the SG for the S function. Disconnect every wire and the belt on the front of it and follow that. If it bench tests okay, move forward to something like the regulator. 1 Share this post Link to post Share on other sites
peter lena 10,070 #3 Posted February 18, 2025 @Greentored found a lot behind dash areas , possible collective debris / hiding a wire chafe ? probably hiding in plane sight , pete Share this post Link to post Share on other sites
ri702bill 13,068 #4 Posted February 18, 2025 (edited) Did you have the battery disconnected for a while?? If so, you may need to polarize the generator. The current needs to be "taught" which direction to flow. Does the ammeter flutter at Zero when running at idle ?? The current is waffling back & forth. Look over the attached ancient Delco Remy files, complete with corny cartoon artwork... one goes over the polarization procedure. Delco Remy IMG-150 Service Bulletin.pdf Delco Remy Regulator Manual 1R-116.pdf delco_remy_regulator_service 1R-111.pdf Delco-Remy SG Repair.pdf DELCO-REMY_SERVICE_BULLETIN.pdf Edited February 18, 2025 by ri702bill 2 1 Share this post Link to post Share on other sites
Handy Don 17,474 #5 Posted February 18, 2025 Definitely Those docs might need a couple passes to make clear sense because of the writing style but they impart a LOT of valuable and applicable information. 👍 1 Share this post Link to post Share on other sites
Achto 32,732 #6 Posted February 18, 2025 17 minutes ago, ri702bill said: If so, you may need to polarize the generator. The current needs to be "taught" which direction to flow. This process is repeated every time that you start the engine. 3 Share this post Link to post Share on other sites
ebinmaine 80,741 #7 Posted February 18, 2025 4 minutes ago, Achto said: This process is repeated every time that you start the engine. Agreed. If the engine is starting okay, polarization is correct. Share this post Link to post Share on other sites
Achto 32,732 #8 Posted February 18, 2025 To test the charging function of the S/G. Connect a multi-meter to the battery. Disconnect the field wire from the S/G and connect a jump wire to the field terminal. Start the engine, touch the open end of your jump wire to ground. You should hear the engine labor a little and you should see your battery voltage increase. If the above test gives you these results, then you have a bad connection or a bad regulator. 6 1 Share this post Link to post Share on other sites
ri702bill 13,068 #9 Posted February 18, 2025 1 hour ago, Achto said: This process is repeated every time that you start the engine. Correct - once the initial polarization is established... Share this post Link to post Share on other sites
Achto 32,732 #10 Posted February 18, 2025 39 minutes ago, ri702bill said: Correct - once the initial polarization is established. To start your engine, you connect battery positive to the armature post on the S/G. There for you polarize the S/G every time that you start your engine. 4 1 Share this post Link to post Share on other sites
pfrederi 21,151 #11 Posted February 18, 2025 2 hours ago, Achto said: To start your engine, you connect battery positive to the armature post on the S/G. There for you polarize the S/G every time that you start your engine. 5 Share this post Link to post Share on other sites
953 nut 69,353 #12 Posted February 19, 2025 This S/G manual should be all you need to figure it out. 1 Share this post Link to post Share on other sites
Greentored 3,221 #13 Posted February 20, 2025 (edited) On 2/18/2025 at 10:36 AM, Achto said: To test the charging function of the S/G. Connect a multi-meter to the battery. Disconnect the field wire from the S/G and connect a jump wire to the field terminal. Start the engine, touch the open end of your jump wire to ground. You should hear the engine labor a little and you should see your battery voltage increase. If the above test gives you these results, then you have a bad connection or a bad regulator. I did this and get absolutely no laboring, voltage jumps, and zero volts out of the arm terminal. The thing acts completely dead but spins the engine over like its perfect. Edited February 20, 2025 by Greentored Share this post Link to post Share on other sites
Greentored 3,221 #14 Posted February 20, 2025 Does the field even come into play during startup? Share this post Link to post Share on other sites
pfrederi 21,151 #15 Posted February 20, 2025 (edited) 18 minutes ago, Greentored said: Does the field even come into play during startup? There are two windings...the start and the charge...the charge does assist the Start when cranking but the start does not assist the charge so your charge coil is probably bad. Edited February 20, 2025 by pfrederi 3 1 Share this post Link to post Share on other sites
Greentored 3,221 #17 Posted March 3, 2025 On 2/20/2025 at 11:09 AM, pfrederi said: There are two windings...the start and the charge...the charge does assist the Start when cranking but the start does not assist the charge so your charge coil is probably bad. Thanks bud. Thank ALL of you for the help! This should be pretty simple but the 'cranks but wont charge' is messing with my brain haha. Field windings being ordered and will update with results. 1 Share this post Link to post Share on other sites
Greentored 3,221 #18 Posted March 12, 2025 Update! Picked up a new set of coils, slapped em in, cleaned everything up all pretty, and shes charging GREAT- in fact, better than she ever has! Full charge by about 1/3 throttle, where I used to need to buzz her right up to get much of anything. I did find a 'bare' spot in the charge coil showing it MAY have been contacting the case, although testing did not show a short to case. Really appreciate all the help fellas! Had NO IDEA the two coils actually performed different functions. P.S.- getting those coils and mounts drawn up to clear the armature- wooooo- no joke! Spend an hour with a pair of 3/8 fine thread bolts, stack of washers, a hammer and big punch, and worked on my 'vocabulary' a bit 1 1 Share this post Link to post Share on other sites
WHX?? 58,150 #19 Posted March 12, 2025 11 minutes ago, Greentored said: Picked up a new set of coils, What was your source? 1 Share this post Link to post Share on other sites
Handy Don 17,474 #20 Posted March 12, 2025 48 minutes ago, Greentored said: Update! Picked up a new set of coils, slapped em in, cleaned everything up all pretty, and shes charging GREAT- in fact, better than she ever has! Full charge by about 1/3 throttle, where I used to need to buzz her right up to get much of anything. Assuming the gen side is doing its job, the rate of charge is tied to the state of the battery and the regulator settings. Sounds to me like this is a good time to confirm you have a strong battery and to recheck the regulator. With that done, you can expect years of good starts! Share this post Link to post Share on other sites
