peter lena 9,782 #1 Posted February 16, 2025 https://www.google.com/search?sca_esv=e06434e0b22fe8e9&rlz=1C1CHBF_enUS866US866&sxsrf=AHTn8zrmgbS9usJKpDOCzO4pyf8tI-zpIg:1739713570432&q=high+stress+grease&spell=1&sa=X&ved=2ahUKEwjZqYGLqsiLAxVqrYkEHdqQEwIQBSgAegQICRAB&biw=1024&bih=607&dpr=1 regularly refer to , bearing failure issues , what you have to realise is the ANGULAR pull on those bearings , also check on how easisy a bearing respondes to movement , have made a point of changing out a bearing , to a wider side grease shield , type / style , so you can eliminate original generic lube , and replace with hi temp , polyurea rated lube , also refer to how easily , my belt drives , move implement , BY HAND AT PTO LEVER START POINT , DRIVE BELT START . experiment with a chronic issue , MAKE A CHANGE , from whats there , that super lube in cabeling is amazing , for all temp slide , use a penetrant , to get the rust out , then the super lube , all my bearings have been , cleand out and re lubed , no belt bounnce , just quiet smooth movement , only a suggestion , pete 2 Share this post Link to post Share on other sites
