pfrederi 20,819 #1 Posted February 6, 2025 Okay so I know the GT series was Wheel horses attempt to have a less expensive tractor. I guess when it came to wiring they took a lesson form Henry Ford...You can have whatever color you like...so long as it is black. #gwest_ca has done a magnificent job colorizing many wiring diagrams. GT-1848 would be easy...all black and skinny almost feel like 18 ga but I guess it is 16ga.. If this tractor works out she may get a complete rewire in Living color. I am not going all in till I get the opportunity top get her really hot and see about the hydro She had a red WH filter. Also guess the PO didn't own a grease gun. Steering sector was bone dry and zerk was encased in dry dirt. 2 5 Share this post Link to post Share on other sites
ri702bill 12,383 #2 Posted February 6, 2025 1 hour ago, pfrederi said: Also guess the PO didn't own a grease gun. Steering sector was bone dry and zerk was encased in dry dirt. That one is easily overlooked or forgotten..... Share this post Link to post Share on other sites
Achto 32,035 #3 Posted February 6, 2025 1 hour ago, pfrederi said: You can have whatever color you like...so long as it is black. I am quite used to all black wiring. Every wire in the generators that work on are black. They do have numbers printed on them...at least until you touch them. Not saying where they have the printing put on them (we'll just say it's below the Texas border) but I do know that it rubs off very easily. To make matters worse, we have a wire printer in house that does a great job. Only way to remove the numbers from our printer is with brake cleaner & a lot of scrubbing. 1 Share this post Link to post Share on other sites
953 nut 67,196 #4 Posted February 7, 2025 Continuity meter and a couple sheets of Brady tags is the way to go. You need ultrabright lighting and good eyesight to see those tracer lines and determine their color. Share this post Link to post Share on other sites
cleat 8,994 #5 Posted February 7, 2025 5 hours ago, pfrederi said: Okay so I know the GT series was Wheel horses attempt to have a less expensive tractor. I guess when it came to wiring they took a lesson form Henry Ford...You can have whatever color you like...so long as it is black. #gwest_ca has done a magnificent job colorizing many wiring diagrams. GT-1848 would be easy...all black and skinny almost feel like 18 ga but I guess it is 16ga.. If this tractor works out she may get a complete rewire in Living color. I am not going all in till I get the opportunity top get her really hot and see about the hydro She had a red WH filter. Also guess the PO didn't own a grease gun. Steering sector was bone dry and zerk was encased in dry dirt. Funny, my GT1600 has a very colourful wire harness. Go figure. Picture is after I cleaned it up and changed things around a bit but the basic harness had all coloured wires. Share this post Link to post Share on other sites
