1968Commando 189 #26 Posted February 3, 2025 Thank you sir for the information. Share this post Link to post Share on other sites
Handy Don 17,476 #27 Posted February 3, 2025 (edited) 1 hour ago, Easton Rich said: I would wire-wheel it and use a self etching primer. In the end it looks like you spent hours sanding it with sandpaper. Advice from a fellow 68’ Commando owner. Wire wheels work depending on the stiffness of the wire and the angle at which they get applied. Stiff wires (as most cups have) can leave deep scratches. Soft wires might not remove the paint (though they will usually remove surface rust). Over large flat surfaces the paint stripping disc like the one you list (or a finer one) will be a LOT faster and leave fewer swirls/scratches. To get the feel of it, test gently on a non-visible or scrap part. Self etching primer is definitely the way to go once you have bare metal. Edited February 3, 2025 by Handy Don 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,552 #28 Posted February 3, 2025 Given your budget it's worth asking: Is your intent a show tractor or a worker that's decently preserved? If a worker, no reason to go to bare metal... sand down, prime and paint, sand and spray with clear coat, or just coat with penetrol and enjoy the tractor... If for show, then proceed with the great suggestions above... 3 Share this post Link to post Share on other sites
ri702bill 13,071 #29 Posted February 3, 2025 DO use the same brand primer & topcoat paints to avoid any compatibliity issues..... Easy way to paint the wheels with the tires on - use playing cards tucked into the deflated bead... and warm the areosol can in hot water between coats... 4 Share this post Link to post Share on other sites
1968Commando 189 #30 Posted February 4, 2025 3 hours ago, Easton Rich said: A very thin layer of bondo, because if you use to much it’s just more to sand off. 2 hours ago, SylvanLakeWH said: Given your budget it's worth asking: Is your intent a show tractor or a worker that's decently preserved? If a worker, no reason to go to bare metal... sand down, prime and paint, sand and spray with clear coat, or just coat with penetrol and enjoy the tractor... If for show, then proceed with the great suggestions above... I plan on it being kinda a mix of both if that makes sense right now I mow yard so the tractor is used for this but I plan on lowering the amount of use it gets so it won’t be a strict show tractor but it won’t be worked hard like I have been using it before this. 2 Share this post Link to post Share on other sites
1968Commando 189 #31 Posted February 4, 2025 3 hours ago, Handy Don said: Wire wheels work depending on the stiffness of the wire and the angle at which they get applied. Stiff wires (as most cups have) can leave deep scratches. Soft wires might not remove the paint (though they will usually remove surface rust). Over large flat surfaces the paint stripping disc like the one you list (or a finer one) will be a LOT faster and leave fewer swirls/scratches. To get the feel of it, test gently on a non-visible or scrap part. Self etching primer is definitely the way to go once you have bare metal. Ok so I am looking for fewer swirls and less scratches so I think my best bet is to run that disc, should I try and find a finer one or should I just use that do you think. Sorry for so much back and forth this is the first ever painting or restoration I’ve done so I’m just trying to make the best choices possible to stay within budget and also have a nice final product 1 Share this post Link to post Share on other sites
Bar Nuthin 3,246 #32 Posted February 4, 2025 (edited) 29 minutes ago, 1968Commando said: Ok so I am looking for fewer swirls and less scratches so I think my best bet is to run that disc, should I try and find a finer one or should I just use that do you think. Sorry for so much back and forth this is the first ever painting or restoration I’ve done so I’m just trying to make the best choices possible to stay within budget and also have a nice final product If you have an orbital sander, you would be fine to use that disc to strip it down, then use the orbital sander with some 80 grit to work out any scratches and swirls in the metal. At that point you could blow it off then wipe it clean with lacquer thinner and be ready apply primer. If you still see scratches, sand the primer with some 180 or 220 grit and re-prime - repeat as needed. Once you're satisfied with the finish, final sand with 320 or 400 grit - You can also use the dk red (fine) ScotchBrite pads for any tricky areas. Wear a mask and keep things as clean as possible. Edited February 4, 2025 by Bar Nuthin 2 Share this post Link to post Share on other sites
Handy Don 17,476 #33 Posted February 4, 2025 @Bar Nuthin is referring to a fairly strong orbital sander. Not one designed for just for polishing. An angle grinder is also usable as long as the disc is rated for the grinder’s RPM. Understand that I am not really a “patina” person and that colors my advice. Removing paint and rust can be slow and discouraging (and dirty and dusty) but if you hang in the results can be quite satisfying. I generally figure two to three hours of prep lets me prime for two or three minutes and then finish coat for another two or three minutes 3 Share this post Link to post Share on other sites
1968Commando 189 #34 Posted February 4, 2025 11 minutes ago, Handy Don said: @Bar Nuthin is referring to a fairly strong orbital sander. Not one designed for just for polishing. An angle grinder is also usable as long as the disc is rated for the grinder’s RPM. Understand that I am not really a “patina” person and that colors my advice. Removing paint and rust can be slow and discouraging (and dirty and dusty) but if you hang in the results can be quite satisfying. I generally figure two to three hours of prep lets me prime for two or three minutes and then finish coat for another two or three minutes Ok I do have a Grinder I also have an air orbital sander available but I think the grinder will work best as the compressor can’t keep up with the demand of air. 2 Share this post Link to post Share on other sites
Pullstart 71,259 #35 Posted February 4, 2025 I’m a little late to the part, but another vote for an E-tank. They are simple to build, and do great work. I’ve run up to 24 volts DC with the best results. You can use a battery with your tender, it just might take a little longer than a good power source. But the beauty is, you can set it up outside before you head to bed or school, and it does the work while you aren’t looking! 3 1 Share this post Link to post Share on other sites
Lee1977 7,781 #36 Posted February 20, 2025 On 2/3/2025 at 1:51 PM, 1968Commando said: Is this too strong of a wheel or do you think it would work? I haven't used that stripping wheel, but every thing I have used made by Gator has been good. Your wire brush will work on the heavy metal like the frame, may be too stiff for the sheet metal if you want a smooth finish. Share this post Link to post Share on other sites
Thor27 892 #37 Posted February 24, 2025 On 2/19/2025 at 5:22 PM, Lee1977 said: I haven't used that stripping wheel, but every thing I have used made by Gator has been good. Your wire brush will work on the heavy metal like the frame, may be too stiff for the sheet metal if you want a smooth finish. Those rock! Expensive, I buy a generic version of those at the jungle site in a sleeve of 10. But they strip well imho. Share this post Link to post Share on other sites
