Alrashid2 429 #1 Posted January 28 Hey guys. I wasn't sure how easy/hard it would be to wire up some taillights for my 312-8, which just has reflectors on the back. I'd almost never need them, but once in a while when plowing I back onto the road. I also am getting a large dead tree felled and the way it is on the property, I'll need to go onto the road back and forth for about 15 yards to get around some boulders and pickup bucked logs. I'm horrible when it comes to electrical things, so rather not mess up and try to install taillights when I would rarely need them. I was thinking of just buying a $20 magnetic bike taillight. One I saw looked decent, lasts 40 hours on a charge, and flashes red. Thought I could just plop the magnetic base onto my rear end between the reflectors and that would be enough. Our road isn't busy but when cars do come theyre going 40 mph... thanks for the advice guys 3 Share this post Link to post Share on other sites
SylvanLakeWH 29,822 #2 Posted January 28 I wired in a cigarette lighter direct to battery. Then just got a magnetic amber flasher and put it on the hood. Works like a charm... I also have regular headlights and taillights along with a very bright red led light on the back (old trailer brake light). I would go more rather than less on lights... also wear a class 3 reflective vest. Your idea will work but it won't be very visible... 3 Share this post Link to post Share on other sites
Ed Kennell 43,783 #3 Posted January 28 (edited) 5 hours ago, SylvanLakeWH said: magnetic amber flasher and put it on the hood Or on a pole. Higher than your head is visible in all directions. Edited January 29 by Ed Kennell 2 1 Share this post Link to post Share on other sites
Alrashid2 429 #4 Posted January 28 Nice that's not a bad idea! Is there a simple procedure for wiring into the battery? Or does it involve pulling apart ignition switches and tapping in there? Share this post Link to post Share on other sites
Ed Kennell 43,783 #5 Posted January 28 6 minutes ago, Alrashid2 said: simple procedure for wiring into the battery? For a short term temporary installation, use two alligator clips directly on the battery. terminals. 4 Share this post Link to post Share on other sites
Alrashid2 429 #6 Posted January 28 Oh that's a good idea and sounds easy enough - guess I just have to be sure to unplug it when the engine is off! Share this post Link to post Share on other sites
Achto 30,196 #7 Posted January 28 (edited) No wiring necessary. Stick it on your tractor, flip the switch. Take it off & recharge it at the end of the day. https://www.amazon.com/Wireless-Security-Emergency-Flashing-Warning/dp/B08112GNBS?gPromoCode=9887143402271754890&gQT=1&ref_=fplfs&smid=A3OF8PDC8TQIDE&source=ps-sl-shoppingads-lpcontext&th=1 Edited January 28 by Achto 2 1 1 Share this post Link to post Share on other sites
TonyToro Jr. 2,183 #8 Posted January 28 1 hour ago, SylvanLakeWH said: I wired in a cigarette lighter direct to battery. Then just got a magnetic amber flasher and put it on the hood. Works like a charm... I also have regular headlights and taillights along with a very bright red led light on the back (old trailer brake light). I would go more rather than less on lights... also wear a class 3 reflective vest. Your idea will work but it won't be very visible... I also did the same thing on my C-121. And also on my C-145 I have rear WHELEN ION amber flashing lights that the public works trucks have on them. cm-chat-media-video-1:921c5e01-9961-3138-8733-92850a611703:10989:0:0.mov 4 Share this post Link to post Share on other sites
peter lena 9,556 #9 Posted January 28 @Alrashid2 been using magnetic bike flashing lights for years , on my seat back , also always wear a reflective vest , when you road plow you want to stand out , between LED headlights / TAIL LIGHTS , you can see the cars moving away from you , astonishing to me how many runners , don,t wear any kind reflective anything , cars barely acknowledge them , pete Share this post Link to post Share on other sites
peter lena 9,556 #10 Posted January 28 @ TONY TORO JR , looks like clean plow blade slide off ? pete Share this post Link to post Share on other sites
TonyToro Jr. 2,183 #11 Posted January 28 49 minutes ago, peter lena said: @ TONY TORO JR , looks like clean plow blade slide off ? pete Heavily doused with silicone lubricant! 1 Share this post Link to post Share on other sites
Alrashid2 429 #12 Posted January 29 Thanks guys! I'll do some thinking on lights and take your advice here. Wanted to ask you all - what do you prefer for setting out on the roadside when you're working near the road? I'll need to park my tractor near the road in between loading up logs. Should I buy orange Traffic Cones, or those orange Emergency Triangles? Share this post Link to post Share on other sites
Wayne0 1,422 #13 Posted January 29 Cones work good. 1 Share this post Link to post Share on other sites
