702854boy 1,073 #1 Posted January 19, 2025 I was thinking about putting in a new seal behind the brake drum on my 702, would anyone have an idea on which way the seal goes in? Share this post Link to post Share on other sites
ebinmaine 80,088 #2 Posted January 19, 2025 Solid side out. When sliding the seal over the axle you may want to tape the key way if it has one. They can be sharp and slice the rubber seal. 1 Share this post Link to post Share on other sites
702854boy 1,073 #3 Posted January 19, 2025 11 minutes ago, ebinmaine said: Solid side out. That is kind of what I was thinking but I just wanted to be sure. Also, that sounds like a good tip to tape up the keyway. I will certainly use that. 1 Share this post Link to post Share on other sites
ri702bill 12,696 #4 Posted January 19, 2025 (edited) Find the appropriate sized driving tool ( PVC pipe, deep socket, etc) first. Remove the old seal, tape the keyseat over. Lightly lube the ID of the new seal and start it - by hand - on the shaft. Then use hand pressure on the driver to get it to the case. Then a few taps on the driver to seat it. Some seals go in flush, some a tad deeper. Note that on the original.... Edited January 19, 2025 by ri702bill 2 Share this post Link to post Share on other sites
702854boy 1,073 #5 Posted January 19, 2025 Would I have to drain the gear oil out or would I be able to just jack it up and tilt it to one side? 1 1 Share this post Link to post Share on other sites
ebinmaine 80,088 #6 Posted January 19, 2025 9 minutes ago, 702854boy said: Would I have to drain the gear oil out or would I be able to just jack it up and tilt it to one side? No drain. No tilt. The gear oil won't be that high. But.... If the gear oil is over 4 years old replace it. The anti foaming agents will be falling out of suspension by then. 3 Share this post Link to post Share on other sites
702854boy 1,073 #7 Posted January 19, 2025 The gear oil isn't that old, we changed it out I think when we put new tubes in the rear tires I think that was in the winter of '22 or early '23. Share this post Link to post Share on other sites
ebinmaine 80,088 #8 Posted January 19, 2025 1 minute ago, 702854boy said: The gear oil isn't that old, we changed it out I think when we put new tubes in the rear tires I think that was in the winter of '22 or early '23. I'd leave that. Share this post Link to post Share on other sites
Lee1977 7,744 #9 Posted January 19, 2025 1 hour ago, ebinmaine said: Solid side out. When sliding the seal over the axle you may want to tape the key way if it has one. They can be sharp and slice the rubber seal. All the brake shafts I have seen are Double D, did they key the the older 3/4" brake shafts. Share this post Link to post Share on other sites
702854boy 1,073 #10 Posted January 19, 2025 22 minutes ago, Lee1977 said: All the brake shafts I have seen are Double D, did they key the the older 3/4" brake shafts. I think so because I had the drum off a few weeks ago and took it over to the parts cleaner and cleaned off all of the gear oil and cleaned up the brake pad and it had a key in the shaft. Share this post Link to post Share on other sites
ri702bill 12,696 #11 Posted January 19, 2025 Yup - 702 has a setscrew on the drum over the key... Share this post Link to post Share on other sites
ebinmaine 80,088 #12 Posted January 19, 2025 39 minutes ago, Lee1977 said: All the brake shafts I have seen are Double D, did they key the the older 3/4" brake shafts. 4 minutes ago, ri702bill said: Yup - 702 has a setscrew on the drum over the key... Trina's mid 60s tractors all have a key and set screw. My mid 70s have the oval or double d type. 1 Share this post Link to post Share on other sites
