siebenaler 114 #1 Posted January 4, 2025 I recently acquired a k241as 10 hp That was removed from a jd 210 It has a very shallow oil pan maybe one inch deep. My question is with this oil pan would it ever work in a wheelhorse tractor? Or do I need to find a deeper oil pan. Share this post Link to post Share on other sites
rmaynard 16,866 #2 Posted January 4, 2025 The 1978, 79 C-101 used a K241AS. Not sure if it's directly compatible. Share this post Link to post Share on other sites
squonk 45,526 #3 Posted January 4, 2025 If you found a deep pan that would work you would also need the connecting rod with a longer oil dipper. 1 Share this post Link to post Share on other sites
pfrederi 19,881 #4 Posted January 5, 2025 If you can bolt it on and have the crank at the right height it will be fine... Share this post Link to post Share on other sites
ebinmaine 77,340 #5 Posted January 5, 2025 4 hours ago, Mark siebenaler said: k241as Got any pics? Share this post Link to post Share on other sites
oliver2-44 11,213 #6 Posted January 5, 2025 (edited) The mid1960's ( 1045 if I recall correctly) use a flat shallow 1" pan to fit the 10hp large block kohler under the hood. The connecting rod had a short dipper on it. Edited January 5, 2025 by oliver2-44 1 Share this post Link to post Share on other sites
Maxwell-8 4,370 #7 Posted January 5, 2025 Maybe mounting it an a shaker plate? 1 Share this post Link to post Share on other sites
ebinmaine 77,340 #8 Posted January 5, 2025 3 hours ago, Maxwell-8 said: Maybe mounting it an a shaker plate? That's what was wondering too. Plate. Adapter. Set of four bolts. Whatever works. 1 Share this post Link to post Share on other sites
953 nut 64,116 #9 Posted January 5, 2025 Here is a thread that will give you the information you need on the different Kohler oil pan configurations. 1 1 Share this post Link to post Share on other sites
ebinmaine 77,340 #11 Posted January 5, 2025 I believe you have 2 options. 1. Use that just as it is by adapting the existing bolt holes to the Wheelhorse frame with a plate and set the correct height. 2. Get a setup from a Wheelhorse of the 1978 ish to 1982 ish period and use that lower frame adapter with solid mounts. Personally I'd try the first. If you do decide to swap that oil pan I'd be interested in buying the one you have now. 1 Share this post Link to post Share on other sites
