PhilD 0 #1 Posted January 1 Hi , Happy New Year Everyone. I need the wire that attaches from the plow angle handle to the little bracket below that allows you to angle the blade. It’s a thin wire , I thought I’d ask before buying a bunch of different sizes for trial and error. Thanks Share this post Link to post Share on other sites
SylvanLakeWH 30,013 #2 Posted January 1 'Bout coat hanger size... or the size they use to hang ceiling tiles... or around 9 gauge... 1 Share this post Link to post Share on other sites
peter lena 9,594 #3 Posted January 2 @PhilD note , how elastic lock nuts , hold perfect movement setting , also strive for squeeze lever , zero play , for maximum rod to steering quadrant movement pull , lubricate as you go , like penetrating oil and red spray grease , that plow can and should move with total solid ease , sound like a rifle bolt . hitch pin clips at rear axel lever stops , pete Share this post Link to post Share on other sites
moe1965 767 #4 Posted January 2 The wire that are used for yard signes works great Share this post Link to post Share on other sites
oliver2-44 11,088 #5 Posted January 2 15 hours ago, SylvanLakeWH said: or the size they use to hang ceiling tiles... or around 9 gauge... Share this post Link to post Share on other sites
Achto 30,308 #6 Posted January 3 (edited) On 1/1/2025 at 5:30 PM, PhilD said: It’s a thin wire , I thought I’d ask before buying a bunch of different sizes for trial and error. Thanks On 1/1/2025 at 5:47 PM, SylvanLakeWH said: 'Bout coat hanger size Straighten out an old wire coat hanger that you probably have laying around some where. This is what I did with mine, works great. Edited January 3 by Achto 1 Share this post Link to post Share on other sites
Chaz54 92 #7 Posted January 3 (edited) I just measured the wire on my plow and it measures 0.122” or about 8 gauge. A coat hanger measures 0.090” or about 11 gauge wire. There is 9 gauge project wire at Lowe’s that would work for you. Edited January 3 by Chaz54 2 Share this post Link to post Share on other sites
