John2189 546 #1 Posted December 28, 2024 What year is my c165 8 speed? Serial number panel is missing. Everything I’ve looked up for the 16 hp kohler says the spec number should be 71311A. My engine spec is 71311, no A. Share this post Link to post Share on other sites
Maxwell-8 4,367 #2 Posted December 28, 2024 (edited) Looking at the files: "1984 C-165 8-Speed model 11-16K801 used K341AS-71311 (A not included at Toro or in PSB #301e)" So probably a 1984 c-165 all the rest of the C-165 have Kohler with a A behind the engine code, it looks like. Edited December 28, 2024 by Maxwell-8 1 Share this post Link to post Share on other sites
pfrederi 18,820 #3 Posted December 28, 2024 A means special oil pan....That ws needed to accommodate the shaker mount system 3 Share this post Link to post Share on other sites
John2189 546 #4 Posted December 28, 2024 29 minutes ago, pfrederi said: A means special oil pan....That ws needed to accommodate the shaker mount system So maybe the engine was replaced and the oil pan was swapped for the shaker? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,612 #6 Posted December 28, 2024 You can use the engine serial number to determine when Kohler made the engine. Still not exact because it could be the current year or the following year. Engines were produced before the tractors. These charts are in the front pages of the Kohler service manuals. 3 Share this post Link to post Share on other sites
John2189 546 #7 Posted December 29, 2024 5 hours ago, gwest_ca said: You can use the engine serial number to determine when Kohler made the engine. Still not exact because it could be the current year or the following year. Engines were produced before the tractors. These charts are in the front pages of the Kohler service manuals. Engine serial starts with 131 so that makes the engine made in 1983. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,612 #8 Posted December 29, 2024 The A that signifies the shallow pan follows the engine model number - K341AS. The S is for electric start. The 71311A spec number would indicate a slight variation of the 71311 spec number. When doing a search 71311A may not show up but 71311 will. At Parts Tree the recognized model is K341-71311 https://www.partstree.com/models/k341-71311-kohler-k-series-engine-made-for-wheel-horse-16hp-11-9kw My guess is the tractor is a 1984 model 11-16K801 Share this post Link to post Share on other sites
Lee1977 7,298 #9 Posted December 29, 2024 The "K" Kohler in you tractor should read - 16 HP If it still has the shaker plate. K341SA 71311 The cover could have been changed or it could have been a mistake at Kohler There was a 1985 312-8 that was wrong had K301SA that should be K301S, HP and number was right. Share this post Link to post Share on other sites
John2189 546 #10 Posted December 29, 2024 6 hours ago, Lee1977 said: The "K" Kohler in you tractor should read - 16 HP If it still has the shaker plate. K341SA 71311 The cover could have been changed or it could have been a mistake at Kohler There was a 1985 312-8 that was wrong had K301SA that should be K301S, HP and number was right. Yes those are the numbers on my 16 hp shaker Share this post Link to post Share on other sites
