Andy T 0 #1 Posted December 27, 2024 Hi all, just a quick question from a newbie, my elderly uncle has asked me to have a look at his Wheel Horse mower/snow plough as it has an oil leak, I'm doing a bit of research but am not sure of the model or type yet, so trying to gather basic info before I load up the van and go to his small holding. Will I need imperial spanners and/or metric? Do they have hydraulic cylinders for the snow plow and are they hydraulic drive or belt/propshaft? Many thanks for any info, Best regards, Andy Share this post Link to post Share on other sites
lynnmor 8,254 #2 Posted December 27, 2024 Just about everything on this side of the pond is imperial. Some, perhaps most, of the tractors are manual lift for the mower and plow. Those with a hydro transmission may have a hydraulic hydraulic cylinder, we can't help much till you get back with a model number. In the meantime you might want to visit the Manuals section and page thru, when you know the tractor, mower and plow model numbers you should download the tractor and implement manuals. 1 1 Share this post Link to post Share on other sites
ri702bill 10,568 #3 Posted December 27, 2024 It may depend upon where the tractor was built. Built in the USA, Fractional (Imperial) with few exceptions. Built in Belgium - Metric. 3 Share this post Link to post Share on other sites
Handy Don 15,171 #4 Posted December 27, 2024 3 hours ago, Andy T said: Many thanks for any info, Well-lit pictures, especially of the model/serial identification plates (tractor and engine) help immensely. After that, clear sides, front, rear, and controls. 1 Share this post Link to post Share on other sites
Maxwell-8 4,370 #5 Posted December 27, 2024 3 hours ago, ri702bill said: It may depend upon where the tractor was built. Built in the USA, Fractional (Imperial) with few exceptions. Built in Belgium - Metric. All Belgium models use imperial only. The Belgium factory didn't make any parts. Just painting and assembly of parts received from the US-factory. 1 1 Share this post Link to post Share on other sites
Mackler 14 #6 Posted December 27, 2024 Welcome to the forum, to be on the safe side I would take a set of AF spanners and a set of Metric spanners and a couple of adjustable ( Crescent } wrenches just in case the odd bolt has been replaced with an imperial Whitworth or BSF fastener which is quite possible with the age of these machines. My Wheel Horse was built in the USA but has a Japanese Kawasaki engine which is all Metric but all the chassis fasteners are AF I look after an ATCO tractor for a friend which has a Briggs & Stratton engine which is AF but the tractor was built in the UK so it is all Metric! 2 Share this post Link to post Share on other sites
Achto 30,190 #7 Posted December 27, 2024 (edited) A lot of common SAE wrench sizes can be substituted with metric. 5/16" = 8mm, 7/16" = 11mm, 1/2 = 13mm, 9/16" = 14mm, 5/8" = 16mm, 11/16" = 17mm, 3/4" = 19mm. Edited December 28, 2024 by Achto 2 Share this post Link to post Share on other sites
Andy T 0 #8 Posted April 13 Hello again, I've finally got details of the tractor, its a 518H with a 18hp Onan engine, I'm trying to find a filter kit for it, but can only find a kit for a D160 with Onan engine. Do any of you knowledgeable folks know if this is the same engine and will the filters fit the 518H? Many thanks in advance Andy Share this post Link to post Share on other sites
oliver2-44 11,061 #9 Posted April 13 Some Oman’s didn’t have engine filters. Guys more knowledgeable on the 518 will be here soon to help. That tractor has the Eaton 700 hydro transmission which does not have a transmission filter. The Eaton 700 is not as strong as the Eaton 1100. The 700 is good for mowing, but not good for ground engaging equipment. 1 Share this post Link to post Share on other sites
Handy Don 15,171 #10 Posted April 14 (edited) 2 hours ago, Andy T said: Hello again, I've finally got details of the tractor, its a 518H with a 18hp Onan engine, I'm trying to find a filter kit for it, but can only find a kit for a D160 with Onan engine. Do any of you knowledgeable folks know if this is the same engine and will the filters fit the 518H? Many thanks in advance Andy I’m not sure where “Lancs” is--Lancashire way north of London? The 18 hp Onan in the 518H and the 16hp Onan in the D160 will be very similar but with their different models (P vs B?), specs, and installation (crosswise vs. longitudinal) I wouldn’t hazard a guess on the interchangeability of an oil filter kit. I am fairly sure that we’ve seen that the 518H export model used the Eaton 1100 transaxle. Quickest external evidence is the implement lift: manual arm = 700, hydraulic = 1100. Edited April 14 by Handy Don 1 Share this post Link to post Share on other sites
kpinnc 16,182 #11 Posted April 14 (edited) 2 hours ago, Handy Don said: I am fairly sure that we’ve seen that the 518H export model used the Eaton 1100 transaxle. This is correct. The European 518-H used the Eaton 1100 and had hydraulic lift. Edited April 14 by kpinnc 1 Share this post Link to post Share on other sites
Andy T 0 #12 Posted April 14 8 hours ago, Handy Don said: I’m not sure where “Lancs” is--Lancashire way north of London? The 18 hp Onan in the 518H and the 16hp Onan in the D160 will be very similar but with their different models (P vs B?), specs, and installation (crosswise vs. longitudinal) I wouldn’t hazard a guess on the interchangeability of an oil filter kit. I am fairly sure that we’ve seen that the 518H export model used the Eaton 1100 transaxle. Quickest external evidence is the implement lift: manual arm = 700, hydraulic = 1100. Yes, Lancs is Lancashire, it is a county in the north of England, further north is the county of Cumbria with the Lake district and then the Scottish border, we still have incursions from the heathens, as Hadrians wall is not what it used to be (only joking) Thanks for the info, it is a manual lift for the implements, so I'm guessing its the 700, I'll take a chance with the D160 filter kit as I can't find an alternative over here. Share this post Link to post Share on other sites
Handy Don 15,171 #13 Posted April 14 (edited) 6 hours ago, Andy T said: so I'm guessing its the 700 It is conceivable that the hydro is an 1100 even without a hydraulic lift. The less obvious determinants of a 700 are: - under the seat, peeking out of a hole in the fender pan, is the cap for the 700’s small, plastic oil reservoir (the 1100 uses the transaxle itself as its reservoir) - looking from the rear, there is NO cylindrical oil filter above the axle between the left rear tire and the transaxle (the 1100 has the oil filter). Arrow points to white filter here: Edited April 14 by Handy Don 1 Share this post Link to post Share on other sites
Andy T 0 #14 Posted April 23 Hi All, I've had a day working on the Wheelhorse, its a 518H with the 1100, as it has the oil filter above the rear axle (thanks Don) The filter kit I ordered was only ok for the oil filters, the air & fuel filters do not fit. The oil leak was coming from the oil drain pipe, which is a unusual remote design, using pipe with an 90 degree elbow screwed into the crankcase, it was loose, absolute pain to get to, and had to unscrew the elbow to realign everything so it would screw in tight on the taper thread. Unfortunately I couldn't get it running as no fuel would come out of the vacuum pump, I could blow fuel through from the tank, so not blocked, checked vacuum pipe coming from carb, seems ok, there was a small amount of effort out of the pump outlet, as a piece of tissue was getting moved whilst cranking the engine over. I couldn't see any tears or perforations in the pump diaphragm. Is this a known issue? Do you know if there is an easy fix or is it pump replacement with an electric pump perhaps? Many thanks again for you help Andy Share this post Link to post Share on other sites
8ntruck 8,332 #15 Posted April 23 My guess on the fuel pump would be something in one of the check valves. I think rebuild kits are available for the pump - on this side of the world. Might be rather scarce on your side. An electric fuel pump is a good option. Many here on the forum have installed them on their tractors with good results. 1 Share this post Link to post Share on other sites
lynnmor 8,254 #16 Posted April 23 4 hours ago, Andy T said: Hi All, I've had a day working on the Wheelhorse, its a 518H with the 1100, as it has the oil filter above the rear axle (thanks Don) The filter kit I ordered was only ok for the oil filters, the air & fuel filters do not fit. The oil leak was coming from the oil drain pipe, which is a unusual remote design, using pipe with an 90 degree elbow screwed into the crankcase, it was loose, absolute pain to get to, and had to unscrew the elbow to realign everything so it would screw in tight on the taper thread. Unfortunately I couldn't get it running as no fuel would come out of the vacuum pump, I could blow fuel through from the tank, so not blocked, checked vacuum pipe coming from carb, seems ok, there was a small amount of effort out of the pump outlet, as a piece of tissue was getting moved whilst cranking the engine over. I couldn't see any tears or perforations in the pump diaphragm. Is this a known issue? Do you know if there is an easy fix or is it pump replacement with an electric pump perhaps? Many thanks again for you help Andy Get filters for an Onan engine, various “kits” are tossed together from suppliers of ill repute. The oil drain is a common problem, I remove the parts, run a 3/8 pipe tap in the engine till it cuts some new threads, then replace the one going into the engine with a new one using red thread locker, make sure that the threads are clean and dry. The other joints can use Teflon tape. Parts are available at any hardware store in the plumbing area. A pulse line runs from the back of the fuel pump to a fitting on the engine block, it is hidden from view so the blower shroud and fuel pump may need to come off to do it right. I have no idea what the previous mechanic did to the system. It is possible that you have a horsepower gauge that connects to a fitting on the intake manifold but an 18 HP may not have that. I believe that the fuel pump is not rebuildable. If you pried it apart it is likely toast. Share this post Link to post Share on other sites
