tractordave3128 0 #1 Posted September 10, 2009 my 312-8 has trouble starting ill turn the key and all it does is say check oil light Share this post Link to post Share on other sites
Sparky-(Admin) 24,485 #2 Posted September 10, 2009 Dave. I split your question out of Charlies vendor area and gave it its own topic here. Mike......... Share this post Link to post Share on other sites
clintonnut 127 #3 Posted September 10, 2009 Check oil? Trace the wire back to the engine and wiggle the connection a little. Charlie Share this post Link to post Share on other sites
canam1991 2 #4 Posted September 10, 2009 there is a plug (4 wires) connecting the engine wires to the tractor wiring harnest unplug it start it and plug it back in so the mag. will charge the battery. or you could fine the oil sensor on the bottom of the oil pan and trace those wire to that plug pull those wires out of the plug and start it. i had it same problem :scratchead: Share this post Link to post Share on other sites
nylyon-(Admin) 8,742 #5 Posted September 11, 2009 Sounds like a safety switch like the clutch or PTO? Share this post Link to post Share on other sites
