courtneysg3 0 #1 Posted December 12, 2024 Hello I have an older toro wheel horse 13-38 hxl that I just purchased and after I brought it home I noticed that the blade engagement cable is moving with no resistance and the blades spin no matter if the pto lever is engaged or not. I noticed that the cable is very loose and the idler arm isn’t moving at all. I was hoping to get some tips on how to correct the issues Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,852 #2 Posted December 12, 2024 Have you looked at the service manual? 1 Share this post Link to post Share on other sites
Ed Kennell 43,805 #3 Posted December 12, 2024 Probably a broken blade engagement idler spring. 1 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,852 #4 Posted December 12, 2024 If you post your tractor's model number and serial number we may find more info. Share this post Link to post Share on other sites
courtneysg3 0 #5 Posted December 12, 2024 The model number is 71191 and the serial number is 5915959 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,852 #6 Posted December 13, 2024 A 71191 search brings up 2 pages of results in no particular order. The 5915859 is a 1995 serial. https://www.wheelhorseforum.com/search/?q=71191&quick=1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,852 #7 Posted December 13, 2024 Here is a parts list so you can see what is still available from Toro. Illustrated parts lists are the best we have showing what goes where. https://www.partstree.com/models/71191-13-38-hxl-toro-lawn-tractor-sn-059000001-059100000-1995/ Share this post Link to post Share on other sites
